turfer
Posted: Sun Jul 15, 2012 12:29 pm Post subject: relacing front panel on mini |
Hi, I have started my first resto project, a 1974 Mini. I have sorted the boot lid, replaced the lip of the bonnet, and rebuilt the bottom of the drivers door.I am about to try changing the front panel. I presume I will need to move the VIN plate on to the new panel, is it ok to drill out the rivets and just re-rivet the plate on to the new one ? |
JC T ONE
Posted: Sun Jul 15, 2012 1:29 pm Post subject: |
Hi, and yes,
both commission and chassi shall be transferred, but the important plate to move over, are the body no (if still there?)
its a long thin plate, with big reverse stamped digits & letters.
its welded on the front panel, same way as the FE no on the innerwing, by the radiator.
good luck, and dont forget to post some pictures we like pictures _________________ http://www.eurods.eu/wp/index.html |
turfer
Posted: Sun Jul 15, 2012 2:17 pm Post subject: |
Thanks for your help. I have seen the other plate that you mentioned, it is located on the nearside of the slam panel. There appears to be 2 vin plates, the one that matches the log book held on by 2 rivets, and a second one sharing one of its rivets. I dont know what its for, is that the commission that you mentioned? |
JC T ONE
Posted: Sun Jul 15, 2012 9:16 pm Post subject: |
Nice to hear that your car still have its body no
so many Mini,s have lost it, when they get restored.
this plate shows what type of car the body is built for.
I would cut the slam panel on each side of it, so you can carefully grind off the spotwelds from the underside, leaving the thin plate untouched.
This way you can spotweld it onto the new frontpanel, and it will look 100% original
You are right, the other Alloy plate, that share the center poprivit, with the chassi plate is the commission plate. _________________ http://www.eurods.eu/wp/index.html |
turfer
Posted: Wed Jul 18, 2012 7:43 pm Post subject: |
Thanks for your help, no excuses for not getting on with it now ! |
JC T ONE
Posted: Wed Jul 18, 2012 9:15 pm Post subject: |
turfer wrote: |
You are welcome and dont for get to post some pictures _________________ http://www.eurods.eu/wp/index.html |
