Posted: Tue Aug 14, 2012 5:27 pm Post subject: Square neck dome head carriage bolts - the hunt continues! |
I'm still looking for a few suitable bolts to retain the demountable rims on the tourer.
They're dome headed, square necked (7/16" across the square), with the threaded section being 3" in length.
I've not found any suppliers that do them thus far (metric equivalents won't do the job), any suggestions? I tried Namrick, and buzzy's local contact, but no joy so far.
Posted: Tue Aug 14, 2012 5:46 pm Post subject: |
What are the closest fit that are too large? if its the thread thats too large it could be turned down, the square could be filed or milled?
mistericeman
Joined: 22 Feb 2012 Posts: 94 Location: Not far from Oldhamabad
Posted: Tue Aug 14, 2012 6:25 pm Post subject: |
Give these chaps a call mate ....
http://www.brianpope.com/
IF they wont post let me know and i can always collect and post on to you as they are only down the road from me .
Posted: Tue Aug 14, 2012 9:31 pm Post subject: |
Last time I called in here they had alsorts of old bolts, so try ringing them as well.
http://goo.gl/maps/Uinbe _________________ Bristols should always come in pairs.
Posted: Tue Aug 14, 2012 11:09 pm Post subject: |
US supplier
http://www.mrgusa.com/pdfs/68-72bmper.pdf
Look at FA1053A on page 5 - may be close. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Posted: Wed Aug 15, 2012 10:25 am Post subject: |
Might help to know, that in USA they are called 'Lug Bolts' I believe, and have absolutely nothing to do with ears. _________________ Dane- roverdriver but not a Viking. |
Posted: Thu Aug 16, 2012 12:38 am Post subject: |
I don't think so, Dane.
In the US, "Lug Nuts" are the wheel nuts on the wheel studs, or lugs. So Lug Bolts would be like the VW Beetle wheel bolts that thread into the hub/drum.
Coach bolts & Carriage bolts are synonymous. They are usually quite long.
I think Bumper Bolts are called the same in both countries. They are usually quite short.
My only concern is that bumper bolts might be made differently from coach/carriage bolts. I have a feeling that the domed bit on a bumper bolt is attached after the square-headed bit is manufactured - a coach/carriage bolt is all one piece. This would presumably affect the strength.
I may be wrong _________________ Mike - MVPeters at comcast.net
Posted: Thu Aug 16, 2012 10:29 am Post subject: |
Mike, The way I understand the American definition is that a 'Lug Bolt' holds the removable part of the wheel. In Rick's case, as with all vehicles with demountable rims, the wheel is designed to remain on the vehicle, and only the rim is removed. AFAIK the terminology was first applied to the bolts for a demountable rim, then later applied to what we would probably call wheel nuts, when the whole wheel became the removable item. _________________ Dane- roverdriver but not a Viking. |
Posted: Thu Aug 16, 2012 7:47 pm Post subject: |
Yes, Dane, that's a good possibility. I really hadn't considered that style of wheel & rim.
It's a bit like commercial truck split rims - I have some good friends in a local truck repair shop - I'll get their terminology input, if it's printable! _________________ Mike - MVPeters at comcast.net
Insanity-74
