Posted: Fri Jan 04, 2013 2:29 pm Post subject: Pressing a halfshaft into a hub, advice needed |
I'm pressing a new halfshaft into a new hub, there is about 4" where the splines mate. As you would expect the father it goes in the greater pressure required, however I'm now 75% in and at 6.5 tons and its not budging , the press will go up to 10 tons, but before I crank it up I wondered if this seemed normal?
Kenham
Posted: Fri Jan 04, 2013 7:33 pm Post subject: |
Hello, what is the diameter of the shaft I have found in the past when things start gettint tight it can become a problem. It can get to a point where it wont go either way without doing a bit of damage. I have pressed shafts out of rusted bushes etc and have got up to 50-60 tons on 2"" size which gets a bit worrying and found it does not take a lot to stop an interference fit. I would think you could go a bit more but half shafts are a bit different, perhaps you could take it back out and see if it is picking up on the splines. Ken |
Posted: Fri Jan 04, 2013 7:36 pm Post subject: |
Well I'm almost there
Ken they are about 1.5" ..... them move with the odd "rifle crack"
Had to crank the pressure up to 15 ton (5 ton more than the press is rated )
And applied a liberal amount of lighted acetylene & oxygen, now have about 1/8" to go.......
May be easier to chop 1/8" off the other end!
Kenham
Posted: Sat Jan 05, 2013 9:49 am Post subject: |
Might fit as it is, thats what I would probably do (chop off). I see there is a little red line left though,looks like about 1/8 to me. I think if you were going too much you would see the shaft bending, that would be the sign to stop!! What vehicle is it off? Looks like youwill be refitting it today anyway. Ken |
Posted: Sat Jan 05, 2013 11:11 am Post subject: |
You hay you have warmed the outer?
Could you take that any more, it might have been an idea to warm that and fit the shaft direct from your chest freezer, I know several collars in Massey back axles are like this, frozen and hot etc.
Be nice to see it go home, but as said will the shaft bend, maybe not to the eye, and also at that pressure does it want to pop out of the press, I always feel sheepish using presses in such circumstances, especially when the item is long like that.
Only other idea, which is not as easy as I say it, can you give it a bit of shock too whilst under pressure, might just be enough. Or even Shock with no pressure, without messing the shaft up, it is amazing what forces you get with a Hammer, compared to a press through shock loading.
Let us know how you get on!
I know of a bigger press if you need one! |
Posted: Sat Jan 05, 2013 11:14 am Post subject: |
How far are they meant to go home is the other question? Do all the splines get covered up? |
Posted: Sat Jan 05, 2013 12:13 pm Post subject: |
Kenham wrote: | Might fit as it is, thats what I would probably do (chop off). I see there is a little red line left though,looks like about 1/8 to me. I think if you were going too much you would see the shaft bending, that would be the sign to stop!! What vehicle is it off? Looks like youwill be refitting it today anyway. Ken |
Hi Ken its off my MGA, I have converted to wire wheels, hence the new hub and halfshaft.
buzzy bee wrote: | How far are they meant to go home is the other question? Do all the splines get covered up? |
Hi Dave, yep just about, If I fit it at the moment it sits about 1/8" away from the other half of the hub assembly (gone as far is it can into the diff) hence if I chopped a bit of the diff end it would fit) It wont fit in our upright freezer unfortunately
Posted: Sat Jan 05, 2013 8:08 pm Post subject: |
Going back to it in the morning, it struck me that the last 1/8" was due to the hub hitting the bearing, so when I tightened everything up the hub seated the bearing to its correct position and all looked good .
I should add that the wheel bearing was fitted by me in 1992, so I have have a bit of an excuse !!!
