standard vanguard phase 2 brake cables
scammellmanswife
PostPosted: Fri Feb 01, 2013 8:42 pm    Post subject: standard vanguard phase 2 brake cables Reply with quote
Help please ! can anyone recommend a place to get brake cables for a standard vanguard phase 2 pick up 1954
PostPosted: Fri Feb 01, 2013 9:21 pm    Post subject: Reply with quote
If you can't get pre-made ones, you might find a company such as this would be able to make them up following the pattern of your old ones. That's assuming you have some old ones to use as a pattern.
http://www.cable-tec.co.uk/applications/bowden_cables.asp
