starter motor spring
1935Hillman
PostPosted: Mon Nov 05, 2012 10:07 pm    Post subject: starter motor spring Reply with quote
I have a Lucas 418G starter motor with a missing return spring (the flimsy looking one). I have bought a new spring but before I try to replace it, does anyone have any experience in replacing this part? I do not want to get stuck into taking it apart if there are any useful tips I should know. Many thanks.
Remmoc
PostPosted: Sun Mar 24, 2013 8:36 pm    Post subject: Reply with quote
If your talking about the bendix return spring You need a compressor tool to remove these , theres a small circlip effort at the very end , compress spring , remove clip , remove compressor and all should go well .
Dont even try without the proper compressor tool or you will remove an eyeball or two and do your self a mischief if it goes wrong Shocked
PostPosted: Sun Mar 24, 2013 9:59 pm    Post subject: Reply with quote
I think he means the lightweight one.
http://tinyurl.com/cw3z4c6
But it looks like the heavy one and the pinion have to be removed in order to install it.
Remmoc
PostPosted: Sun Mar 24, 2013 10:07 pm    Post subject: Reply with quote
oops Embarassed
PostPosted: Sun Mar 24, 2013 10:20 pm    Post subject: Reply with quote
Anyway, welcome to the forum Remmoc Smile
Remmoc
PostPosted: Mon Mar 25, 2013 12:17 am    Post subject: Reply with quote
Thanks , plainly i need new reading glasses Embarassed . I recon im thinking M35.
Embarassed Embarassed
