Joined: 30 Apr 2013 Posts: 3839 Location: The Somerset Levels
Posted: Wed Mar 15, 2023 11:50 am Post subject: |
I hope this doesn't come over as teaching Granny to ...erc. but I would suggest buying the very best one you can afford. |
Posted: Wed Mar 15, 2023 4:09 pm Post subject: |
True, but I think this is pretty good as a 'doer-upper' don't you think? _________________ Various Rootes Vehicles. |
Joined: 20 Aug 2008 Posts: 1393 Location: Netherlands
Posted: Wed Mar 15, 2023 4:36 pm Post subject: |
Looks like a reasonable example. Bit of rust, not too bad. These have a massive chassis. If you are accustomed to modern cars, you will be pleasantly surprised how comfortable these cars are. It is a quality car which shows in many ways, the way levers, handles and switches work for example. Not sporty at all but a smooth 6 cylinder engine. _________________ a car stops being fun when it becomes an investment |
Posted: Wed Mar 15, 2023 5:28 pm Post subject: |
Rootes75 wrote: | True, but I think this is pretty good as a 'doer-upper' don't you think? |
I guess it depends on how far you want to go with it. Better take on something like this and improve to your own satisfaction
rather than pay a lot more for something that has cosmetically been done up by someone else just to flip.
It is too easy for the unscrupulous to cut corners.
Posted: Wed Mar 15, 2023 6:09 pm Post subject: |
Rick wrote: | Aren't they particularly prone to rotting around the rear end, underneath? Just a vague recollection I have. I suppose that's the case with anything of that age, if I ever went for one it'd make sense to buy one already in regular use I think as prices are still fairly sensible. Saying that the asking price for this example doesn't seem too crazy.
RJ |
Rick. If you get to see one of these with the idea of buying, try and get the seller to let you jack it up and remove a n/s rear wheel.
Apart from observing any oil on the rear brake drums you want to check the chassis around the bump stop area as this is prone to rot.
Fortunately Rover used good steel so the area can be repaired but the car would need to be cheap.
More worrying would be a cracked exhaust manifold. This happens because the retaining bolts have been done up too tight;
not allowing for expansion. This is a common problem and spares have all but dried up.
Another thing to watch out for in pre 1960 cars is a clatter from the engine. It is a warning that the camshaft has seen better days.
Probably due to infrequent oil changes. If it sounds expensive it probably is! |
