ford 7w ten running problems
Goto page Previous  1, 2, 3
spitfirebob
PostPosted: Tue Jun 21, 2016 6:38 pm    Post subject: Reply with quote
petelang wrote:
Did your engine builder not run test the engine?
I just wonder if they taped over the manifold holes and forgot to remove it when fitted?
No,they just rebuilt engine without a test bed
spitfirebob
PostPosted: Tue Jun 21, 2016 6:40 pm    Post subject: Reply with quote
Does it improve as it warms up?
There's no noticeable change when warm
ALW Ford Popular
PostPosted: Thu Jun 23, 2016 8:18 pm    Post subject: Reply with quote
Thinking about this - any chance they got the timing out on the crank / cam via chain? A few teeth out perhaps??
spitfirebob
PostPosted: Sat Jun 25, 2016 2:52 pm    Post subject: Reply with quote
Right,after changing all ignition pates still the same!! Sad
But have noticed that carb seems to be throwing alot of fuel in so much so that when I open throttle a mist of fuel comes out of top cover
Also air mixture screw doesn't make a difference in any position and even fully removed!
Could this actually be causing all my problems?? Something isn't right somewhere in carb so could lack of power be caused by overfuelling?
Kenham
PostPosted: Sat Jun 25, 2016 3:42 pm    Post subject: Reply with quote
Sounds like the choke is not returning properly.
PostPosted: Sat Jun 25, 2016 4:09 pm    Post subject: Reply with quote
Bob,
Have you checked the float in the carb.? Take out and give it a shake to see if there is any liquid inside. Also check the needle and seat adjustment. It sounds like the fuel level is too high.
Art
spitfirebob
PostPosted: Sat Jun 25, 2016 5:52 pm    Post subject: Reply with quote
Battle recommences in the morning then! Strip carb down and recheck everything Mad
PostPosted: Sat Jun 25, 2016 6:50 pm    Post subject: Reply with quote
If the mixture adjustment makes no difference I'd still wonder about it drawing in air somewhere it shouldn't be, making it run hyper-lean. What colour are the plugs?
I remember on my E83W, revving the engine while peering into the top of the carb (air inlet, cover removed) you could see a mist of fuel splurt across. Normal stuff iirc.
spitfirebob
PostPosted: Sat Jun 25, 2016 7:31 pm    Post subject: Reply with quote
Plugs are quite black!
It's not a fine mist across the chamber it actually wets my hand working the throttle
spitfirebob
PostPosted: Mon Jul 11, 2016 6:53 pm    Post subject: Reply with quote
Have changed the carb and overfuelling problem still there
Could fuel pump be the cause?
PostPosted: Mon Jul 11, 2016 9:19 pm    Post subject: Reply with quote
These carbs don't have the accelerator pump do they?
PostPosted: Mon Jul 11, 2016 10:37 pm    Post subject: Reply with quote
Nope, not if it's the standard Zenith carb.
PostPosted: Mon Jul 11, 2016 10:48 pm    Post subject: Reply with quote
I'd be surprised if it was (assuming it's the standard mechanical pump, bolted to the side of the block), in theory the pump only supplies what the needle valve (& float) allow it to pump into the float chamber.
As I've mentioned before, I remember being able to see fuel splurt across when peering into the carb as the engine was revved on my E83Ws, but never enough to drown the engine or mist/spray out above the carb's air intake while running.
Are you able to post up any photos of the engine, carb, and so on, just in case something obvious is in evidence? Even a video uploaded to somewhere online might be very useful.
spitfirebob
PostPosted: Fri Sep 02, 2016 8:51 pm    Post subject: Reply with quote
Sorry for not replying to anybodys posts but got fed up with car and had a break from it for a few weeks, but....Got it running at last!
Turns out that engine builder had set timing about 2 1/2 teeth out
Runs lovely and smooth now Smile Smile
Page 3 of 3
