| What is your preference |
| 4 post ramp |
73% |
[ 19 ] |
| 2 post ramp |
26% |
[ 7 ] |
| Total Votes : 26 |
Posted: Fri Jun 19, 2009 1:01 pm Post subject: |
I hope I dont have to dig it up either
First section now filled with concrete and smoothed out. I need to leave it to set before I can start trying to get a good finish on it
Good to see you back Greeney  _________________ ROVER
One of Britain's Fine Cars |
Posted: Fri Jul 03, 2009 9:28 pm Post subject: |
I had a bit of a problem with the fibres that were in the concrete of the first section as they were not properly mixed in and clumps of them rose to the surface when levelling the concrete out, so I decided not to have anymore fibres. Now I am unsure if I did the correct thing or not, as when I concreted the other two sections I ran into problems, but that could have been down to the extreme heatwave we had. The surface of the centre section (with fibres) turned out reasonably smooth and for a first attempt I was happy with the finish, the second section was drying out too quick and in desperation I had to cover it with polythene whilst the surface was still wet, so some damage did occur. The final section which was 2" deeper and half a metre wider also dried out quicker than I would have liked but now to the extent of the previous section.
What this means is that I will have to hire a floor grinder once the concrete has been down for a minimum of 28 days and tidy it up
Before filling both side bays I set out the rebar and dowels
This picture clearly shows the fibres on the surface.
Second section covered to prevent drying out too quick and largest third section before the polythene went on
A week after the last batch of concrete was laid and the polythene has now been removed, the two end bays certainly do need some grinding down but this shouldn't be too big a job
For those following this thread you will remember that I had problems with drain levels and decided to have the rainwater drain above ground and build a wall to hide the pipe. Well I decided that it was time to try my hand at laying some concrete blocks and this was the final part of the garage to complete this part of the project
Today I handed my completion paperwork into Building Control so I am hoping that they will pay me a visit next week and hand me the Building Warrant.
I can't get the cars into the garage for now as the ground is a different level to the floor, so now to decide what to do with the outside _________________ ROVER
Ray the rocker
Posted: Sat Jul 04, 2009 9:06 pm Post subject: post subject |
Looking really good 47---can`t wait to see that ramp fitted, then your labours will be the toast of the town!!!
Cheers---Ray the Rocker... |
Posted: Sat Jul 04, 2009 9:20 pm Post subject: |
Once Building Control have given me the ticket the ramp will be fitted  _________________ ROVER
Posted: Sat Jul 04, 2009 11:45 pm Post subject: |
Looking good!
Have you a picture from the front outside looking in, like you have taken several times during the build, would be good to see the finished article as a whole?
Posted: Sun Jul 05, 2009 2:46 am Post subject: |
Will do Dave  _________________ ROVER
Posted: Sun Jul 05, 2009 8:07 pm Post subject: |
Here you go Dave, still got the yard to sort out but I'm unsure just yet what to do with it
With a little bit of thought I managed to cut some timber and make temporary ramps so that I could get the cars in the garage. There is loads of space between the cars and at the rear so I won't need to worry about squeezing into a tight space
Posted: Sun Jul 05, 2009 8:27 pm Post subject: |
Looks very good indeed!
Look forward to your next installment! hehe
Posted: Sun Jul 05, 2009 9:58 pm Post subject: |
Well the good news is the cars have been sitting on the concrete for 4 hours and the concrete hasn't cracked
Next installment will be the ramp beign fitted  _________________ ROVER
Posted: Tue Jul 07, 2009 11:58 am Post subject: |
I called Building Control today to enquire as to when I might expect to have the inspection done. The officer asked me about the electrics in the garage, enquired as to whether I managed to sort out the drains, then said that my certificate would be posted out........ I thought I wasn't hearing correctly and asked him if he was coming out to which he replied that he had seen enough the last time he visited (which was the only visit I had from him regarding the drains) therefore no need for another look.....I still don't believe it....
Ramp will be fitted in two weeks time  _________________ ROVER
Ray the rocker
Posted: Tue Jul 07, 2009 8:13 pm Post subject: post subject |
I bet you slid into your armchair with a big sigh of relief---no one to tell you off about some thing or other--as they do !!
Cheers Ray the Rocker... |
Posted: Tue Jul 07, 2009 11:47 pm Post subject: |
I opened a bottle of wine tonight and had a celebratory drink  _________________ ROVER
Posted: Thu Jul 23, 2009 12:14 am Post subject: |
Finally got the ramp fitted and working, not without a few gremlins that required to be sorted out and I have to order some limit switch brackets so not 100% finished. The good news is it does work so next job will be raising the roof space
Posted: Thu Jul 23, 2009 12:27 am Post subject: |
Looks very posh, and very exciting!
Now you just have to remember you are working on a ramp, my mate has had some awful disasters on his, quite comical too, but I won't divulge! hehe
I bet you are really happy, really excited about getting a gremlin to fix on something, or are there plenty waiting to be done!
Very impressed!
wrinx
Posted: Sun Aug 30, 2009 6:45 pm Post subject: |
Sooooo jealous! Very professional building
wrinx _________________ www.alfaromeo155.co.uk | www.alfamatta.co.uk
