Gjneves
Posted: Fri May 15, 2015 11:33 am Post subject: Morris 8 E Series Front Axle Retainers |
Hy guys,
I starter to fix my problem brake and when I open front brake wheels was a mess, with axle grease on the plate and brake-shoes. Now I remove all and cleaned. I ask if you recomended change my felt washer, Have a new modern solution?
My felt washer:
[/img]
Thanks,
Gonçalo Neves |
goneps
Posted: Fri May 15, 2015 10:23 pm Post subject: |
Your best bet is to change the wheel bearings for the modern sealed type of ball races, then you don't have to bother about lubricating them and no grease leaks out. If they're the same as for the earlier Eights then they are standard sizes readily available at reasonable cost.
Richard |
SpiggyTopes
Posted: Sat May 16, 2015 6:29 am Post subject: |
Hi Sr Neves,
Sorry I can't help with your problem, but I am moving to Lisboa in July and would love to see your car .... |
