Soda blasting
Bayliss Thomas
PostPosted: Thu Dec 03, 2009 8:13 pm    Post subject: Soda blasting Reply with quote
Has anyone any experience of this type of blasting media and how have you got on with it?
jotto
PostPosted: Tue Jan 12, 2010 10:35 pm    Post subject: Re: Soda blasting Reply with quote
I have seen it being used to remove graffiti and on 2 cars locally. Soda is good in that it does not put much heat in to the panel and so warping is reduced but if you have rust, it will not remove anything more than slight surface rust.
The residue also protects the bare metal for a short time.
www.pamsghia.co.uk
Bayliss Thomas
PostPosted: Thu Feb 04, 2010 12:28 pm    Post subject: Reply with quote
Thanks for the helpful info, I wanted to remove rust so will look at other options.
michael1703
PostPosted: Thu Feb 04, 2010 10:32 pm    Post subject: Reply with quote
whereabouts are you bayliss?
ive got a blaster but for big stuff i use
Bettinson Blast CleaningBlast Cleaning
Tel: 01379 740278| 47, Low St, Oakley, Eye, Suffolk
Bayliss Thomas
PostPosted: Mon Feb 08, 2010 8:16 pm    Post subject: Reply with quote
Well blow me, I live just down the road, Occold, Eye.
But I really want to consider the purchase of an machine, as well as my vintage car I also have an use cleaning off decades of old paint and crud from beams in my little cottage.
michael1703
PostPosted: Mon Feb 08, 2010 8:18 pm    Post subject: Reply with quote
i live VERY close to you! i'll PM you
Car-Nut
PostPosted: Thu Nov 25, 2010 12:51 pm    Post subject: Reply with quote
Ive just linned up a guy in Lancashire to soda blast some exhaust manifolds for me I'll post some pics of the outcome when there done..
Car-Nut
'62 S1 Jaguar E-Type 3.8 FHC
'70 420G - 13th from last RHD
'70 420G - 17th from last RHD
michael1703
PostPosted: Fri Nov 26, 2010 9:12 am    Post subject: Reply with quote
why soda blast a manifold?
the idea of soda is its kinder to materials, you could blast a manifold with pretty much any abrasive with no problem
Car-Nut
PostPosted: Fri Nov 26, 2010 9:29 am    Post subject: Reply with quote
To clean the rust and old paint off.... Smile
Car-Nut
1935Hillman
PostPosted: Fri Nov 26, 2010 11:04 am    Post subject: soda blaster Reply with quote
Hi there,
I bought a small soda blast outfit from the guys who do all the classic car shows, MSB. I wanted it for car parts and also for my work with timber restoration and repairs. It was a bit too subtle and wasn't as effective as I had hoped with the soda and I have to say I have resorted to grit for most things. (I haven't cleaned any bodywork admittedly, just cast items and folded brackets etc. Good little bit of kit though and has proved very useful for cleaning small bits quickly, certainly beats drill and wire brush.
Car-Nut
PostPosted: Fri Nov 26, 2010 11:56 am    Post subject: Reply with quote
My guy has given me a price and said if I wasnt happy he wouldnt charge he cant be fairer than that..... Wink
Car-Nut
michael1703
PostPosted: Fri Nov 26, 2010 7:46 pm    Post subject: Reply with quote
Soda doesnt remove rust
Nic Jarman
PostPosted: Tue Nov 30, 2010 12:13 pm    Post subject: Reply with quote
In America I have seen the blaster use ground wallnut shells. Very environmentaly friendly man.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Tue Nov 30, 2010 3:25 pm    Post subject: Reply with quote
There is an article about this type of blasting in the Classic Motor Autojumbler this month.
I'll try and scan and post on here if you wish.
PostPosted: Tue Nov 30, 2010 3:40 pm    Post subject: Reply with quote
Might want to get the nod from John H of the 'jumbler before doing so Smile
