Posted: Sun Jan 22, 2012 10:14 pm Post subject: |
I have done a decoke on the marina coupe General Lee but I am doing it outside weather permitting. I also need to check the brakes and give it a grease then it will be ready for MOT....should be ok.
Roll on May for our first show at East Kilbride or I might fancy the show at Carlisle Airport on the same day. Has anyone ever been to the Carlisle Airport show first Sunday in May. _________________ The Clan Chieftain |
52classic
Posted: Wed Jan 25, 2012 10:48 pm Post subject: |
Just booked for the first show of the season. Coleford at Easter. That will be an outing for the F350 this year, shouldn't take too much preparation, the 'hammered' look enhances a military vehicle IMHO!
It will be a few weeks yet 'til the 100e comes out of storage and I am hopeful that as ever she'll respond to a good clean and a service to be ready for another season.
Having got going on the 2002 at long last, progress is slow but I am pleased with how much I've done. Rear floors (including some home fabricated subframe mounts) are done, one sill replaced and it is down on its wheels and rolling to be turned around to do the other side in my 1.5 car garage.
All this whilst building an extension on our house. Who else would start a project in November which involved taking the roof off? Still, I got the shell up and roof back on a few days before Christmas so I can enjoy the indoor second fix. |
Joined: 31 Jul 2009 Posts: 1775 Location: Market Warsop, Nottinghamshire
Posted: Thu Jan 26, 2012 9:48 am Post subject: |
52classic wrote: | ... Who else would start a project in November which involved taking the roof off? ... |
Yup - been there, done that. We didn't get the roof back on until April |
Posted: Thu Jan 26, 2012 11:32 am Post subject: |
Cambridge - Finish welding in the new floorpan, outriggers, chassis and start cutting the old passenger sill out.
A35 (NO) - Try yet again to find the source of the annoying knocking from the engine. For the record, it only knocks when the fan belt is fitted, when it's removed the noise stops, and if it's overtightened it nearly stops. Already replaced the water pump and dynamo.
A35 (SHX) Fit new rear shock absorbers.
Atlantic - Get it out of the garage, re-rubber the brake master cylinder, adjust the steering column so I can fit under the wheel, sort out the charging system, and weld up the drivers floorpan. Check the tyre sizes as I suspect they're too wide (extremely difficult to get the rear ones on and off without stretching the bodywork) and try and get insurance for me to drive it.
How much of the above will actually get done, I don't know. _________________ Richard Hughes |
Posted: Thu Jan 26, 2012 6:00 pm Post subject: |
I am slowly working may way through re-commissioning (or should that be comissioning, since I don't think it has been run since restoration in the 1980s) of my newly imported Saxon. Much of the work so far has been finding/modifying things to make it UK-legal (lights, horn, registration plates, etc) and I am now going through the mechanics prior to MOTing so that I can get it registered. I fired it up for the first time last week, which revealed a flaw in the fuel system, so I have now reworked that, and it looks like I may now have to adjust (hopefully) or rebuild the clutch, and then we are just about there...
Meanwhile, I am also doing some building work on the garage itself, which explains the tip in the background |
52classic
Posted: Thu Jan 26, 2012 6:22 pm Post subject: |
Mike, what a glorious looking vehicle! Space to work and a car trailer too, lucky man.
I have never tinkered with anything from that era, maybe one day. |
Posted: Thu Jan 26, 2012 8:19 pm Post subject: |
Thought you might like this? It's from a very old magazine and yours is the first surviving one I have seen.
_________________ Due to the onset of my mid eighties I'm no longer sprightly and rarely seen in my Austin special. I have written a book though. https://amzn.eu/d/7rwRRqL |
Posted: Thu Jan 26, 2012 9:34 pm Post subject: |
Yup - that's the fella! Looks like a Model 14, rather than mine, which is a Model A, but basically the same thing.
They are pretty scarce in the UK - I have managed to trace three others so far... |
Ironhead
Joined: 28 Mar 2010 Posts: 458 Location: Leicestershire
Posted: Sat Feb 04, 2012 5:33 pm Post subject: |
Churchill Johnson wrote: | Ironhead wrote: | i'm trying to source front brake shoes for my 1200 Herald to get it through the MOT.unobtainable say the TSSC | Try on e-bay they have two lots for sale for one put in E.B.C. , the shoes if you have 8" drums are the same as the Reliant rebel 64-68 600and700cc. | have now bought a set of shoes off that e-bay-er.thanks Churchill |
JohnDale
Posted: Sun Feb 05, 2012 5:35 pm Post subject: |
Steering box out of Zephyr,overhauled(parts from my friend in NZ), refitted & tested. Triumph treated to new set of coreplugs before anti-freezing - bigger job than it sounds as exhaust & inlet manifolds require removing for access plus dizzy from the other side - old ones not in too bad a condition but it's something I can now forget about,cheers,JD. _________________ 1958 Ford Zephyr Mk2 Convertible
1976 Ford Granada Ghia. |
Mog
Posted: Mon Feb 06, 2012 11:02 am Post subject: |
Richard H. try replacing the fan belt on your A35 [no] If there is a crack in it it will make a noise. If all else fails, try the cheapest solution ! |
Posted: Mon Feb 06, 2012 4:34 pm Post subject: |
This is an odd one:
Check the V angle carefully on the belt - if it's not correct for the pulleys it 'snaps' out as it turns. The noise is horrific. Spray it with water & see if it changes. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
