Alternative to Metro 12" wheels?
3xpendable
PostPosted: Tue Mar 06, 2012 2:20 pm    Post subject: Alternative to Metro 12" wheels? Reply with quote
My dad is thinking of buying a metro as a runaround, but is put off by the fact the tyres are an odd size and hence will be expensive to replace. Does anyone know if any other wheels with a more mainstream tyre size will fit?
2013 Dodge Durango R/T Hemi
1965 Ford Anglia 106e Estate (LHD)
1964 Ford Anglia 105E 1500 GT (Dad)
1980 Porsche 911 SC Targa (Uncle)
1971 MGB GT (V8 project) -SOLD 2016
2005 MINI Cooper S JCW - SOLD 2016
PostPosted: Tue Mar 06, 2012 2:35 pm    Post subject: Reply with quote
Didn't the early MG Metro Turbos have larger diameter alloy wheels than the steelies fitted to less fruity versions? Or was it just that they were a different style?
emmerson
PostPosted: Tue Mar 06, 2012 10:19 pm    Post subject: Reply with quote
I think (!) some Metros had imperial sized wheels and others had metric, but don't know what the difference is. One is much more expensive than the other. Not much help really, is it? Confused
RotaryBri
PostPosted: Wed Mar 07, 2012 1:37 am    Post subject: Reply with quote
Could they be Dunlop Denovo wheels - the early run flat system? They were fitted as OE on some Metro models. It is impossible to get these tyres anymore so a wheel change is the best answer.
Keep Torqueing,
RotaryBri
1976 NSU Ro80
JC T ONE
PostPosted: Wed Mar 07, 2012 3:31 am    Post subject: Re: Alternative to Metro 12" wheels? Reply with quote
No problem Smile ANY Mini wheel after 1984 will fit, its the same bolt pattern/circle, and incase it has a center guide / boss ?
then remove that, its no problem I have done this many times, the wheels line up perfectly on the studs.
If he is worried about the 12" tyres ? (dont know why he would be?)
then buy some 13" Mini wheels. there are LOADS for sale .
PostPosted: Wed Mar 07, 2012 3:20 pm    Post subject: Reply with quote
It's the metric tyres that are particularly dear, simply because metric wheels and tyres never caught on and so they quickly became "specials". It was a very short lived thing that BL and others - BMW for instance - dabbled in at the time, and the usual workaround was to fit some later imperial wheels to take cheaper rubber. Mind you, I don't know how cheap a 12" tyre would be today - how many cars were fitted with them, aside from later Minis and Metros, and are any new cars today sold with 12" rims?
bob2
PostPosted: Wed Mar 07, 2012 9:22 pm    Post subject: Reply with quote
Best action would be as JC said, fit 13 inch wheels from a mini specialist or from ebay, find a cheap set complete with good tyres!
Metros look better with 13s too!
