Posted: Fri Jan 25, 2013 9:25 pm Post subject: |
Neat find Rick, I have never come across one of those, says its 1971...
Peter it's about 1900 miles to Lisbon from where you live |
Posted: Fri Jan 25, 2013 11:07 pm Post subject: |
D4B wrote: | Neat find Rick, I have never come across one of those, says its 1971...
I suppose it's not bad but where's the fun? It doesn't look rusty enough. |
Posted: Sat Jan 26, 2013 5:27 pm Post subject: |
Today I welded my home made door handle in place
Posted: Sat Jan 26, 2013 7:10 pm Post subject: |
Steve, that must be a new door section at the bottom is it? From this side, at least it's starting to come together by the look of it.
What are you using to strip paint? Sooty? |
Posted: Sat Jan 26, 2013 8:24 pm Post subject: |
To strip paint, so far it's all been done with a wire wheel on
my angle grinder..... but perhaps its time for some paint
stripper... |
Posted: Sat Jan 26, 2013 9:40 pm Post subject: |
colwyn500 wrote: | You do hear horror stories regarding filler but that door really does leave you gasping "WHY?!!!"
Because its cheap!...I found similar in my 1939 Morris 8 SE, we can be critical, but if someone hadn't applied the filler in the 60's & 70's to my Morris, the car would have probably been scrapped....
Kelsham
Posted: Sun Jan 27, 2013 9:58 am Post subject: |
Colwyn 500, did you suffer any damage to the panel with the polycarbide discs?
I used the drill mounted type with complete satisfaction, however when I tried the one's supplied for my angle grinder I found the panel rippled.
I put it down to the generation of heat.
I have an XJS bonnet to strip and am wary of using the grinder discs.
regards Kels. |
Posted: Sun Jan 27, 2013 10:46 am Post subject: |
Kelsham wrote: | Colwyn 500, did you suffer any damage to the panel with the polycarbide discs?
regards Kels. |
I have found that the discs work best with very light pressure and I haven't noticed heat build-up to that level. However, the car I am working on has a very compact and rigid shape. It only has the factory paintand no filler to remove. Normally it doesnt even spark the steel so I really am just removing paint. |
Posted: Fri Feb 22, 2013 10:06 pm Post subject: |
Found a few hours yesterday to have another crack at that beastly
corner pillar...
It was very cold at about zero degrees with a bitter wind, but I think it made the welds cool quicker which was handy...
Previously:
Then yesterday:
Posted: Fri Feb 22, 2013 10:11 pm Post subject: |
Posted: Mon Feb 25, 2013 4:55 pm Post subject: |
Steve. that is starting to look fairly complete. any more horror sections? |
Posted: Mon Feb 25, 2013 5:14 pm Post subject: |
Hi Peter,
Yes photos are often very forgiving / misleading.....
There is a lot more welding to do on this than I anticipated, but isn't that nearly always the way?
I have just discovered the cab floor and front right lower door pillar and front valence are in need of repair:
