Ford V8 Pilot - 1949
SplodgesDad
PostPosted: Sat Apr 06, 2013 5:34 pm    Post subject: Reply with quote
Hi Des
Whereabouts are you?
I've seen a couple of websites advertising full stainless systems but they really aren't cheap!
PostPosted: Sat Apr 06, 2013 5:57 pm    Post subject: Reply with quote
JP Exhausts in Macclesfield, will make you any sort of pipe, in mild or stainless.
Re the electronic ignition, if the car has a dynamo make sure the electronics has adequate protection against the noise and spikes, otherwise its may be a short lived system Shocked
Dave :
SplodgesDad
PostPosted: Sat Apr 06, 2013 6:11 pm    Post subject: Reply with quote
Thanks for the info Dave, will check them out.
Luckily enough she's had an alternator conversion.
Landy Des
PostPosted: Sat Apr 06, 2013 10:23 pm    Post subject: Reply with quote
SplodgesDad wrote:
Hi Des
I'm in Buckinghamshire - I don't need an exhaust in the short term but I intend to hang on to the Pilot for a good few years so am looking for a sort of wish list for the future.
Steering wheel repair though is going to be required soon I think.
SplodgesDad
PostPosted: Sat Apr 06, 2013 10:35 pm    Post subject: Reply with quote
I'm looking at Powerflow at the moment as we have a depot locally. Will keep you updated as to progress.
I'll keep a look out for steering wheels, what's up with yours?
Landy Des
PostPosted: Sat Apr 06, 2013 11:03 pm    Post subject: Reply with quote
The steering wheel is badly cracked at the spokes and feels a bit "springy" when I have to heave the steering round to get it off the drive onto the road.
I've found a place on line, but haven't contacted them yet.
They actually show a Pilot wheel on the website
http://www.steeringwheelrestoration.co.uk/index.php
SplodgesDad
PostPosted: Sun Apr 21, 2013 10:46 pm    Post subject: Reply with quote
Managed to patch the exhaust up till I can get some new down pipes made. In the meantime I need to find a replacement dizzy cap and rotor arm as I'm still not convinced they're working correctly.
I can't get a decent reliable spark at the plugs despite cleaning the points and resetting the gaps. The centre carbon brush from the coil lead had broken, so I replaced this but without much joy. I've checked the continuity back to the coil but it is 'iffy' at best. The coil lead seems ok, so I think its dizzy cap/rotor arm time........
btw, thanks for the help with the electronic ignition question, I've ordered a set from Frank Jolley, a really helpful guy, especially when you find out exactly which dizzy is actually fitted to the car!
Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed
V8 Nutter
PostPosted: Mon Apr 22, 2013 8:40 pm    Post subject: Reply with quote
Nordian Services should be able to help with the parts you need. Not sure of the address, but they have a website
SplodgesDad
PostPosted: Wed May 08, 2013 12:57 pm    Post subject: Reply with quote
Thanks guys, she's up and running again now and off to Autostyl in Chacewater for her respray......
Standby for some more pictures.
In the meantime, I've been a very lucky boy indeed and have just managed to acquire another classic which will be joining Amelia in our new venture. I'm now going to head over to the Armstrong Siddeley forum to say hello Smile
SplodgesDad
PostPosted: Fri May 10, 2013 11:04 pm    Post subject: Reply with quote
Amelia in for her respray, looking rather naked......
[img][/img]
The existing paint hasn't adhered well at all and can be peeled of by hand!
[img][/img]
PostPosted: Sat May 11, 2013 8:48 am    Post subject: Reply with quote
So will all the maroon have to be stripped off, or is it just in places that it's peeling?
SplodgesDad
PostPosted: Sat May 11, 2013 9:41 pm    Post subject: Reply with quote
Hi Rick
Unfortunately it's cracking and bubbling all over, so it's all coming off!
The primer used in the original restoration is waxy like putty and it's not providing a good key at all. Crying or Very sad
It's going to be done in a modern 2 pack, so jt should last better.
SplodgesDad
PostPosted: Sat May 11, 2013 10:05 pm    Post subject: Reply with quote
Hi Rick
SplodgesDad
PostPosted: Wed Jul 03, 2013 5:45 pm    Post subject: Reply with quote
A quick update on Amelia. The guy doing the work found some iffy previous repairs and has now taken her back to bare metal.
Unfortunately for us, this now means that the original time and budget are truly blown!
I'll update with more pics when I get a bit of time.
SplodgesDad
PostPosted: Wed Jul 03, 2013 5:46 pm    Post subject: Reply with quote
Page 2 of 4
