Part stripped spark plug thread ..alloy head
PostPosted: Sat Mar 15, 2014 7:33 pm    Post subject: Part stripped spark plug thread ..alloy head Reply with quote
Bugger Mad
I must have removed and reinserted spark plugs in the Stag more times than .....well I have done it a lot ! Smile
Today whilst bringing the Stag out of winter hibernation I removed all the plugs to check and clean. All was well apart from putting the plug back in number 4 cylinder, actually one one the easier cylinders to access the plugs.
I always screw the plugs in with thumb and forefinger , only using a wrench for the final tightening ......No 4 plug did not want to go back Sad , the thread on the plug was clean and fine after 10 mins of trying to fit it , I decided to run a plug tap through the thread, thinking it may just need cleaning up.
The tap also took some persuading , but did take , but only for a turn and a half , then it went stiff Confused What do I do back out or carry on?....I backed out a few times, but then decided it was all or nothing, and ran the tap with what I would describe as medium force.
So I can now insert the plug , but with only half the turns it should have, the plug seals and the engine runs fine, so what are my options;
Leave as is until there is a future problem
Put a helicoil in now, it's one of the easier cylinder to do Smile
Never change plug 4 again !
Advice welcome Smile
PostPosted: Sat Mar 15, 2014 8:06 pm    Post subject: Reply with quote
Id leave it and see how it goes, maybe a smear of copperslip on the thread to ease it a little?
Kev
PostPosted: Sat Mar 15, 2014 9:38 pm    Post subject: Reply with quote
Technically it may not be the correct solution, but as Kev suggests I'd leave it alone, for now at least, and see how it goes on a few local-ish jaunts.
PostPosted: Sat Mar 15, 2014 11:27 pm    Post subject: Reply with quote
Been there done that and everything correct to the book and I also agree with what has been said ie leave it well alone.
You have nothing to loose - remove it only when you have to - then use an old plug as thread chaser to clean out the threads - this has worked for me twice now without problems and both are still OK after 10+ years
NEVER EVER remove/replace plugs when an alloy head is even remotely warm leave 24hours min. Use thread lube to replace and quarter turn MAX.
I did loose a plug on on my P5B V8 because of under tightening
Embarassed and often find them then "loosish"
Rover P2
Morris Mini Traveller Mk2
ajlelectronics
PostPosted: Sun Mar 16, 2014 8:34 pm    Post subject: Reply with quote
Well you would.
Evans Waterless Coolants
goneps
PostPosted: Mon Mar 17, 2014 1:11 am    Post subject: Reply with quote
Dave,
I presume these are alloy heads? If so, when you next have to remove that plug the best answer is to Helicoil it, and if I were in your shoes I'd bite the bullet and do the whole lot as an insurance for the future.
If Triumph hadn't been so cheap-skate they'd have used steel inserts in the first place. Fine threads (M14 x 1.25 if they're standard plugs) are not suitable for soft materials! My 1964 BMW motorcycle had steel plug inserts in its alloy heads, and there was never a problem in the 36 years I owned it.
Richard
PostPosted: Wed Mar 19, 2014 5:37 pm    Post subject: Reply with quote
I'd be inclined to fit a Helicoil now otherwise you might end up with an emergency repair instead of one at your leisure.
PostPosted: Wed Mar 19, 2014 5:44 pm    Post subject: Reply with quote
How do you prevent swarf getting in the cylinder when helicoiling?
or is it only to be done with head off?
goneps
PostPosted: Wed Mar 19, 2014 10:41 pm    Post subject: Reply with quote
Safest to remove the head(s), of course, but in dire circumstances a liberal coating of grease on the tap will retain virtually all of the swarf. Ditto for snapping off the tang of the Helicoil.
PostPosted: Sat Mar 22, 2014 8:02 pm    Post subject: Reply with quote
Thanks for the replies Smile
I'm going to see how it goes! Logic being that the worst that can happen its that I may loose 1 out of 8 cylinders, so would probably be able to limp home Smile
I have fitted inserts before with the head in situ, doing as Richard suggested greasing the drill and tap, but also making sure that the inlet valve is open with a plate on the carb, tapped to take an airline fitting so that compressed air can be blown in, encouraging swaf to stay out of the cylinder, + it's an aluminium head so whilst any contamination in the cylinder is not desirable, it's softer than the rings and cylinder walls.
Will keep you posted
winchman
PostPosted: Tue Apr 01, 2014 11:15 am    Post subject: Reply with quote
I have used a Dyson with a straw taped to the end of the hose, it works well.
It will come in handy even if you never use it.
Rosco663
PostPosted: Sun Apr 06, 2014 2:28 am    Post subject: Reply with quote
ukdave2002 wrote:
..........making sure that the inlet valve is open with a plate on the carb, tapped to take an airline fitting so that compressed air can be blown in, encouraging swaf to stay out of the cylinder,......
Excellent idea Idea
Rosco
Greeney in France
PostPosted: Sun Apr 06, 2014 9:01 am    Post subject: Reply with quote
I dont know if it past this but I have a couple of different sizes of these and they work really well.
You put then in, find the inner threads and then expand them to unthread.
www.OldFrenchCars.com
Jonv8
PostPosted: Thu May 01, 2014 6:24 pm    Post subject: Reply with quote
That is a tool I've been trying to design in my head for ages....
Who makes them ?
Greeney in France
PostPosted: Thu May 01, 2014 6:27 pm    Post subject: Reply with quote
Its a Sealey MS003
