TribalElder
Joined: 01 Oct 2012 Posts: 67 Location: Franskton Vic Australia
Posted: Thu Jul 03, 2014 10:06 am Post subject: |
My 46 E series starts at close to 100 then drops after a few minutes to 70psi. I reco'd this motor last year but before that it was quite happy to run aqt around 35-45psi. _________________ Ian from Oz
It's hard to run like an Emu
When you are girt by Numbats |
goneps
Posted: Thu Jul 03, 2014 11:48 pm Post subject: |
The figures quoted by TribalElder are excessive for both the Series E and earlier UB engines, indicating either that his gauge is over-reading or that the pressure relief valve is u/s, or both. The pressure relief valve should open at 60psi., therefore pressure should never exceed that figure. 50psi. at start-up and 20 at idle suggest the engine is in reasonable condition, but of course will be affected by type and grade of oil and ambient temperature, etc.
The pressure relief valve is there because the plain bearings of these motors, especially the white metalled big-end bearings of the UB engine (1934-38 Eights, ie. 35/Series I/Series II), neither need nor were designed for very high pressures. With a newly-overhauled UB motor you could expect 50-60psi. at fast idle after a cold start and, once hot, 50-55psi. at 40-45mph. and 35-40psi. at idle.
These motors operate quite satisfactorily at somewhat lower pressures, but less than 25psi. at the above cruising speed is becoming rather marginal, in my experience.
Richard |
peterd60
Posted: Fri Jul 04, 2014 11:05 am Post subject: |
goneps wrote: | The figures quoted by TribalElder are excessive for both the Series E and earlier UB engines, indicating either that his gauge is over-reading or that the pressure relief valve is u/s, or both. The pressure relief valve should open at 60psi., therefore pressure should never exceed that figure. 50psi. at start-up and 20 at idle suggest the engine is in reasonable condition, but of course will be affected by type and grade of oil and ambient temperature, etc.
Richard | Thank you for the information Peter |
rabbito
Joined: 21 Jan 2014 Posts: 15 Location: victoria australia
Posted: Wed Jul 09, 2014 11:23 am Post subject: Y series morris utilevan rear seats |
I would like to know if any of you morris folk own a Y series utilevan with fold down rear set if you do could you please put up some detail off the hinge system or contact me to discuss it over
Hoo Roo & have a nice day
Rabbito |
peterd60
Posted: Mon Jul 14, 2014 7:54 pm Post subject: some more pics |
I am am back off holiday now so will had some more pics of how i am gettin on with the car Peter |
peterd60
Posted: Thu Jul 17, 2014 4:12 pm Post subject: |
At last the body has come off, been a real struggle, that's the worst bit over with hopefully. I will keep you up to date. Thanks Peter.
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img] |
peterd60
Posted: Sun Aug 10, 2014 12:06 pm Post subject: Update! |
A new update for you all:
Hi a couple of more pictures here, the body is now stripped and etched primed ready for welding. I've started work on the chassis, i will upload some more pictures later on.
p.s. I'm in need of a brake master cylinder, if anyone could help? Thanks.
[img][/img]
[img][/img]
[img][/img]
[URL=http://s851.photobucket.com/user/peterd2013/media/morris84_zpsa1e106fc.jpg.html]
[/URL]
welder
Joined: 26 Nov 2007 Posts: 265 Location: North Warwickshire
Posted: Sun Aug 10, 2014 7:17 pm Post subject: |
Peter, you state that you need a clutch master cylinder. Unless someone has, at some point, fitted a hydraulic clutch system you don't, as they are mechanically operated, mate.
Clutch pedal is affixed directly to the release-bearing shaft on the gearbox. If you need any of these components let me know as I have loads of spares.
Perhaps you meant brake master cylinder? In which case I regret that I can't help.
Ian |
peterd60
Posted: Sun Aug 10, 2014 10:15 pm Post subject: Master cylinder |
Hi you are correct it is a brake master cylinder I need not a clutch master cylinder thanks for the message |
Bob T
Joined: 16 Nov 2010 Posts: 128 Location: Sudbury, Suffolk
Posted: Sun Aug 10, 2014 10:47 pm Post subject: |
Hi, I know it's not local but Ian Harris sells them in the uk,
Bob T |
peterd60
Posted: Mon Sep 29, 2014 5:43 pm Post subject: Morris 8 Update |
This is an update on my Morris 8 series 1, suspension all welded and painted, ready for the rebuild now.
[/img][img]
[/img][img]
[/img][img]
[/img] |
bjacko
Posted: Fri Oct 03, 2014 7:48 am Post subject: Morris 8 resto |
Looking very good.
I presume you did an alignment check and a detailed inspection for cracks ? These chassis are notorious for distortion and cracking. |
Posted: Fri Oct 03, 2014 12:27 pm Post subject: |
Peter,
Did you do the chassis repairs yourself or use a specialist?
Art |
peterd60
Posted: Sat Oct 04, 2014 10:45 am Post subject: Re: Morris 8 resto |
bjacko wrote: | Looking very good.
It was all crack tested and fine, it was all jigged up before it was welded, and is now ready for the body. |
peterd60
Posted: Sat Oct 04, 2014 10:46 am Post subject: |
47Jag wrote: | Peter,
Art |
No I did it all myself. Now ready for the body. |
