Need advice on installing King Pin Bushings on 1933 Chevy
roywood
PostPosted: Mon Jul 28, 2014 2:56 pm    Post subject: Need advice on installing King Pin Bushings on 1933 Chevy Reply with quote
Starting to restore my grandfathers 33 chevy coupe. I can't get the new King pin bushings installed. Is there a trick?
PostPosted: Mon Jul 28, 2014 3:41 pm    Post subject: Reply with quote
I would suggest that you post on:- http://forums.aaca.org/f120/ OR
http://forums.aaca.org/f155/ There's a lot of expertise there.
Art
PostPosted: Mon Jul 28, 2014 3:50 pm    Post subject: Reply with quote
Hi Roy,
Welcome to the forum.
Not on a Chevy but a Jaguar, I found that I could push them out or in using a large vice and an appropriate diameter socket spanner to bear on the bush.
They still need to be reamed with a pilot reamer after fitting.
V8 Nutter
PostPosted: Mon Jul 28, 2014 8:47 pm    Post subject: Reply with quote
Good advice from Peter. The king pin reamer could be difficult to find. Paul at the American Truckshop, at Strensham near Worcester has some American king pin reamers, if he has one that is suitable he may hire it to you. You can contact him through his website The American Trucksop, but he is not theasiest person to deal with
