Rear demister help
PostPosted: Wed Aug 27, 2014 4:50 pm    Post subject: Rear demister help Reply with quote
My Singer has a period Lucas, stick on demister fitted, to be fair, it works really well.
One point that bugs me however is the huge, green illuminated toggle switch that is fitted to it (under dash)
I have a nice chrome bracket with 2 mounting holes so I have bought this switch and warning light.
The wiring from demister is a simple swap-over as it has 2 wires to the switch currently..how do I wire in the warning light properly though?
Kev Very Happy
PostPosted: Wed Aug 27, 2014 5:11 pm    Post subject: Reply with quote
Hi Kev
the warning lamp needs to be wired in parallel to the screen element.
PostPosted: Wed Aug 27, 2014 5:35 pm    Post subject: Reply with quote
ukdave2002 wrote:
Hi Kev
dave
are you any good at drawing diagrams? Very Happy
Kev
PostPosted: Wed Aug 27, 2014 9:45 pm    Post subject: Reply with quote
Kev,
From the switch terminal that the wire to the element is on add another wire and connect it to one side of the warning lamp, the other terminal get connected to earth. So on the switch you will have one feed wire (ignition controlled), the other terminal has the two wires.
Art
PostPosted: Thu Aug 28, 2014 10:51 am    Post subject: Reply with quote
Yep, that makes sense.
Many thanks
Kev
ka
PostPosted: Fri Aug 29, 2014 6:44 am    Post subject: Reply with quote
If you are moving the switch, it would be an ideal time to put a relay in the circuit and take the load off the switch.
KA
Better three than four.
