alec.elliot
Joined: 28 Feb 2012 Posts: 58 Location: Worcestershire
Posted: Sat Dec 06, 2014 9:12 am Post subject: Synchro ring ball bearings |
Hi Chaps and Chapesses.
So during the overhaul of a four speed Morris 8 Series E gearbox I took the synchro rings off the hub and managed to keep all of the ball bearings and springs held within. (Foolish lad I hear you say.)
My question....How do you get all of the little bleeders back in. I had a couple of attempts last night using a jubilee clip but I have now lost three of the 1/4" ball bearings somewhere around the garage.
Any other good ideas? I am sure I am not the first person to have faced this problem and wont be the last.
All the best
Alec |
Posted: Sat Dec 06, 2014 12:06 pm Post subject: |
Alec
Jubilee clip works for me without problems, I also put a dab of grease on each of the balls and springs to initially keep them in place, before the clip it fitted.
The clip needs to be large enough to fit round all the protruding ball bearings, and then simply tightened up to the point were the hub can slide over and keep everything in place.
alec.elliot
Posted: Sat Dec 06, 2014 12:27 pm Post subject: |
Hi Dave
I will give it another go.
Alec |
Posted: Sat Dec 06, 2014 6:57 pm Post subject: |
..and do it in a cloth or polythene bag. Then you don't need to look all over the workshop for the balls and springs if things go wrong.
alec.elliot
Posted: Sun Dec 07, 2014 7:13 pm Post subject: |
I cannot believe it but after a quick search of the garage floor I was able to retrieve all of the balls and on the third attempt with a jubilee clip and a poly bag both rings are now back in place with a full complement of balls and springs.
Thanks for the help
Best regards
Alec |
Farmer John
Posted: Sun Dec 07, 2014 7:47 pm Post subject: M8 gbox |
Hi Alec, I was impressed by your having saved a jubilee clip that was perfect for the task, as unlikely as it looked! As soon as I saw that clip I knew you would be successful.
John |
