Posted: Wed Jan 28, 2015 1:43 pm Post subject: 1954 Singer Hunter |
A friend of mine in Finland is restoring one of the above (admittedly a car that I am unfamiliar with) He is missing the entire switch assembly from the centre of the steering column. Can anyone suggest a source or another make/model that fitted the same component? It is Lucas manufacture.
Paul (pjbeaumont@toucansurf.com) or pm. |
Posted: Wed Jan 28, 2015 2:57 pm Post subject: |
It looks a bit unique..
Posted: Thu Jan 29, 2015 1:21 pm Post subject: |
Yes Peter, that was my thought when I found that picture! I am hoping someone will prove me wrong!
Paul |
Posted: Thu Jan 29, 2015 11:26 pm Post subject: |
Basically, a follow on from the SM1500. http://www.singercars.com/profiles/hunter.html
I last saw a hunter about 20 years ago in a rough and ready classic car lot near Daventry. The guy kept most of the cars out in the open although the better ones were kept in a barn. I remember a particularly nice Horch (for runner of AUDI)
The chances of finding a donor car are pretty slim.... however stranger things have happened! You never can tell what will turn up.
I presume you are looking for the indicator switch mechanism?
Something to look out for at Beaulieu perhaps? |
Posted: Fri Jan 30, 2015 9:52 am Post subject: |
There will almost certainly be other Lucas horn/indicator manettes that use the same stator tube diameter and are located with the same flange in the steering wheel.
