Wanted
JC T ONE
PostPosted: Tue May 19, 2015 2:05 am    Post subject: Wanted Reply with quote
Hi all,
is there anyone inhere that can help with one (or more) of the following parts.
1 - a Lucas Black rubber cover, for a std Lucas negative helmet connector.
2 - a sound insulation blanket in Silver / Grey vinyl, with diamond shaped pattern. Looks like one of them old radiator / grill winter Muffs.
3 - a round exhaust silencer, with roll welded ends, and the in & out pipes (small = std Mini) positioned in different height.
4 - some Blue floor mat for a Austin/Morris 11/1300 = ADO 16 .
Thanks for looking.
Jens Christian
Here you go Rick = jc(AT)showcars.dk
phone 0045 51304698
PostPosted: Tue May 19, 2015 7:15 am    Post subject: Reply with quote
Hi Jens - can you add some contact details please, as per t&cs http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=10724
thanks, RJ
JC T ONE
PostPosted: Tue May 19, 2015 12:33 pm    Post subject: Reply with quote
thanks, RJ
Done Smile
PostPosted: Tue May 19, 2015 1:50 pm    Post subject: Reply with quote
thanks, RJ
Done Smile
Excellent, thanks Smile
JC T ONE
PostPosted: Tue May 19, 2015 2:37 pm    Post subject: Reply with quote
Now here I opened my mailbox expecting it to be full of replies - and found nout.
Hmm better add some more "common" items to it then Wink
I am also looking for 4 crossply tyres with White walls size = 10" .
used are also of interest.
Jens Christian
bob2
PostPosted: Wed May 20, 2015 10:06 am    Post subject: Reply with quote
Don't put white walls on a mini Jens, never liked them myself!!!
I'd much prefer it with a set of reverse rims on!! Smile
JC T ONE
PostPosted: Fri May 22, 2015 1:18 am    Post subject: Reply with quote
Hi B2,
Probably not a big chance to find any Rolling Eyes but rest asured = I will fit them if i found 4 Cool and it will stay on its narrow std rims, with std hub caps Cool
Just bought a used but original rear subframe from Califfen Cool
JC T ONE
PostPosted: Mon May 25, 2015 12:34 am    Post subject: Reply with quote
New item added to my wants list.
A Lucas switch dated 9.61 - 10.61 or 11.61 - only need the switch.
Thanks
bob2
PostPosted: Mon May 25, 2015 8:43 am    Post subject: Reply with quote
I do need a couple of toggle switches too, but not too fussed about the year!!
I admire your attention to these small details though!
JC T ONE
PostPosted: Wed Jun 10, 2015 2:28 am    Post subject: Reply with quote
Today I polished & fitted the 6 sided nut I got from a Mini friend Friday.
I can now paint the White nylon housing, and have the correct look, once its fitted to the panel.
