christine lowery
Joined: 30 Sep 2009 Posts: 496 Location: wallsend tyne and wear
Posted: Sun Jun 07, 2015 6:00 pm Post subject: |
she has a B&& beta hitch on so 50mm at that age
christine |
Jublybug
Posted: Mon Jun 08, 2015 6:39 pm Post subject: |
Seemed to be a good fit on the Skoda Octavia I've been moveing it around on .
Any one know where I can get a replacement ram from? |
Jublybug
Posted: Tue Aug 11, 2015 6:13 pm Post subject: |
Interior from the front . Il get a pic of the sink area its got all the seat / bed foam aswell |
christine lowery
Jublybug
Posted: Wed Aug 12, 2015 8:36 pm Post subject: |
Thanks for the heads up on the camper, but due to kiss of my storage the vans going to have to be sold . 😞
Jim |
Jublybug
Posted: Thu Sep 10, 2015 10:15 pm Post subject: |
Storage issue has now been resolved and the vans back on . This weekend I'm going to remove the front window frame and polish it ready for new glass .
Jim |
Jublybug
Posted: Sat Sep 26, 2015 4:03 pm Post subject: |
Did some polishing of the van today , removed the old cooker(I've got a better vintage replacement) and the fridge . I think I'm going to replace the floor as its rotted the ply wile it was sat with the door open in the hedge .
The other two windows frames I already removed are polished ready for glass hopefully next week .
Jim |
Jublybug
Posted: Sat Oct 03, 2015 4:00 pm Post subject: |
Had a set back on the glass ive now found a supplier of the missing seals ,so geting there
Progress pics from today
Jublybug
Posted: Sat Oct 03, 2015 4:27 pm Post subject: |
Sink clean and cooker back area (was quite nasty) striped out gas cupboard and the near side seat/ wheel arch area .all unscrewed without any dramas
The bigest mouse toilet eve ever seen |
Jublybug
Posted: Sat Oct 03, 2015 4:39 pm Post subject: |
Bed frame out
There's quite a bit of damp wood due to the missing glass but the main struts in the glass fiber are ok
Bits stacked and labled
And my first find a 70s tidly wink woohoo
We also pulled up the laminate flooring and under felt stuff back to the original . All the bits that are salvageable will be going back in anything not will be used as a template and remade . New floor is a must to as id like to see what's under the original .im gessing some old mouse hotels
Jim |
Jublybug
Posted: Sat Oct 17, 2015 6:00 pm Post subject: |
Small amount of progress today ,managed to dismantle the other side bed and both upright cupboards but I'm running out of space inside to store the dismantled bits so that's to overcome .
Jim
I think where going to half the cupboard hight as you step in to open it up a bit and make it lighter ,found more mouse poo and maggots today so I think its a right move to lift and replace the floor |
Dalek63
Posted: Sun Oct 18, 2015 8:31 pm Post subject: |
Many a project has been condemned to the rubbish tip or sold off because the new owner has tried to do to much at one go, id advise you to do a little at a time. Not strip it down to its last nut and bolt then make a start on restoration. That way often leads to disaster. _________________ I can resist anything except temptation ! ( Oscar Wilde)
Jublybug
Posted: Mon Oct 19, 2015 7:00 pm Post subject: |
Its the only way to do it properly I cant replace the bad floor with the interior in on top of it , due to work its a slow process but itl get done
Jim |
Jublybug
Posted: Sat Oct 24, 2015 10:29 pm Post subject: |
Well last bit out today . Started with this
And ended with this
All came out pretty nicely next to make it water tight then floor up
Jim |
Posted: Sun Oct 25, 2015 10:08 am Post subject: |
Does the floor extend under the floor?
Kev |
