Ellis
Joined: 07 Mar 2011 Posts: 1382 Location: Betws y Coed, North Wales
Posted: Sat Jun 18, 2016 10:38 pm Post subject: Which gold paint for ornamental gates? |
Can I ask you all for advice on a non motoring subject, please?
Which make of gold paint would you use on iron ornamental gates?
I have tried all the "big" name paints with fairly poor results despite good preparation. The finish looks artificial or gaudy and does not last long.
I have Googled the subject but the same names come up.
I did ask the groundsman of one of the local big country houses last year and he uses sheets of gold leaf.
"His" gates look beautiful but I am not in the same league as aristocracy or country squire! He also told me that he coats the black paint with copal and I may try that.
Any recommendations?
Thank you.
Ellis _________________ Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet |
Posted: Sun Jun 19, 2016 10:02 am Post subject: |
There is a product called 'Guilder's Paste'. The one that I have used is made in the USA by 'Baroque Art'. I have used it on a variety of surfaces, but merely tested it on wrought iron. It works well, goes a long way, but would need a lacquer coat to protect the finish. As it is available in a range of colours, artistic effects can be created.
My daughter (in the USA) uses it for very artistic effects on hand-cast chess pieces.
There might be a U.K. equivalent. The USA one is available in the U.K. _________________ Dane- roverdriver but not a Viking. |
Ellis
Posted: Sun Jun 19, 2016 7:39 pm Post subject: |
roverdriver wrote: | There is a product called 'Guilder's Paste'. The one that I have used is made in the USA by 'Baroque Art'. I have used it on a variety of surfaces, but merely tested it on wrought iron. It works well
There might be a U.K. equivalent. The USA one is available in the U.K. |
Thank you very much Dane. I hadn't heard of this before but it is available direct from Amazon UK and I have ordered the "Antique Gold" variety this afternoon.
Ellis
Posted: Mon Jun 20, 2016 12:34 pm Post subject: |
Thank you Peter.
The cost is not going to break the bank so I am going to order this product as well and the universal sealer recommended in the advert.
Posted: Mon Jun 20, 2016 12:41 pm Post subject: |
Ellis wrote: | Thank you Peter.
Ellis |
I would guess, as with many products, one has to try it and await the results. |
