Miken
Posted: Mon Jun 12, 2017 12:18 pm Post subject: Re: 1927 Cowley |
bjacko wrote: | Yes the sheets have an illustration for each tool. If you are a Morris Register member they are available on their website. |
OK thanks |
Miken
Posted: Wed Jun 14, 2017 10:05 pm Post subject: |
I had a problem with one of my headlamps not working.
On investigation I discovered that the 90 year old bakelite bayonet fitting had disintegrated.
This is how I have repaired it:
Here is the old broken part;
I bought a universal 2 pin bayonet fitting. Sawed off the remains of the old fitting and made up a little brass socket on my lathe to accept the new fitting;
It fits together like this;
I made a tool to expand the bush into the reflector;
Here it is expanded securely into the reflector;
I have assembled the new socket into the brass bush using loctite bearing retainer rather than a permanent retainer in case i ever want to dismantle it.
The other lamp looks a bit ropey so I will do that one the same. |
Posted: Thu Jun 15, 2017 12:19 am Post subject: |
Fantastic work. Love the way you handled this instead of going the way which most "restorers" think is the norm: replace by new. _________________ a car stops being fun when it becomes an investment |
Posted: Thu Jun 15, 2017 8:19 am Post subject: |
I am amazed by the effort you put into sorting out all these problems so precisely. It makes me wonder how I manage to restore cars without a lathe or the skill to use one. Top work! |
Miken
Posted: Thu Jun 15, 2017 9:27 am Post subject: |
Thanks for the kind comments.
My projects are usually driven by having more enthusiasm than cash.
A lathe, even a small model makers version can be invaluable for all sorts of renovation work.
I think everyone should own one!
There are so many times when you find you need a spacer, bush, stud or non standard bolt. |
Posted: Thu Jun 15, 2017 3:39 pm Post subject: |
Mike,
Nice work. The only comment I would make would be to split the bushing and have a clamp. The usual method to focus these lamps is sliding the bulb holder in or out.
Art |
Miken
Posted: Fri Jun 16, 2017 6:21 am Post subject: |
Yes that would have worked. I haven't seen them like that so didn't think of it. |
Miken
Posted: Fri Jun 16, 2017 10:08 pm Post subject: |
Mr Morris thoughtfully provided a tapped hole in the top of the Cowley cylinder head to enable a length of rod to be inserted to determine TDC.
This is filled with a 8 x 1mm threaded plug.
Turning the engine over using the starting handle I found it a bit tricky to accurately locate TDC so i made this up to assist. It allows you to see exactly when to stop winding.
Miken
Posted: Wed Jun 21, 2017 10:30 pm Post subject: |
Excellent. |
Penguin45
Posted: Wed Jun 21, 2017 11:47 pm Post subject: |
Very well done indeed.
Posted: Thu Jun 22, 2017 8:34 am Post subject: |
superb news, enjoyed the video too, many thanks for that
kev |
Posted: Thu Jun 22, 2017 11:42 am Post subject: |
Well done. Nice you had the weather for that run too. |
Miken
Posted: Thu Jun 22, 2017 8:29 pm Post subject: |
Thanks all.
Been out and about today.
A couple of times I have thought about giving it a polish.
But settled for cleaning the greasy hand prints off the windscreen.
Just noticed that in the video you can see the crappy chrome plate on the r/h budgie mirror literally peeling off in the fearsome 25mph breeze. |
