Kleftiwallah
Posted: Sun Jun 11, 2017 6:14 pm Post subject: Solex 26FV carb' |
Anyone got any clues / hints /suggestions about the basic setting up of this carburettor when starting up for the first time?
Cheers, Tony. _________________ It may work in practice, but not necessarily in theory! |
Posted: Sun Jun 11, 2017 6:43 pm Post subject: |
Hi Tony,
It's a fairly simple carburetor. The only adjustments are the slow running mixture screw and idle speed. It won't be critical if these are not correctly adjusted for first starting. You could screw it fully in the mixture screw then unscrew perhaps 1.5 turns but to honest you can't really adjust it until the engine has reached normal working temperature.
Set the idle speed adjustment just to very slightly open the butterfly.
Kleftiwallah
Posted: Tue Jun 13, 2017 9:07 pm Post subject: |
Thanks Peter for that informative & heartening reply.
