Charging the battery
Miken
PostPosted: Tue Jul 18, 2017 6:56 pm    Post subject: Charging the battery Reply with quote
When charging the 12v battery on my 27 Morris Cowley (dynastarter and magneto ignition, neg earth) is it necessary to disconnect both (or any) battery leads?
Thanks
Mike
PostPosted: Tue Jul 18, 2017 7:22 pm    Post subject: Reply with quote
Hi Mike,
With the car at rest with the engine and ancillaries switched off the battery is not connected to anything and you can safely connect a charger to it.
Miken
PostPosted: Tue Jul 18, 2017 8:08 pm    Post subject: Reply with quote
Thank you Peter.
MN
jp928
PostPosted: Tue Aug 15, 2017 1:36 am    Post subject: Reply with quote
I have a garage queen - doesnt get enough usage - and I keep a trickle charger on it while parked. I used a charge socket like a cigarette lighter socket, with a positive connection centre (2 brass blades that accept a pin like a headphone plug) , and concealed it under the rear licence plate, connected to the battery with a fused line. Its connection is such that I have to walk over it to get to the car, so I dont forget to remove it. With a direct battery connection I can isolate the battery from the rest of the car if necessary to do work, but still leave the charger connected.
Like this plug, and socket to suit, with a cap.
http://www.arindustrialsupplies.com.au/narva-thermoplastic-merit-accessory-plug-82108bl.html
jp 26 Rover 9
