Goto page Previous  1, 2, 3 ... 119, 120, 121
PostPosted: Thu Apr 11, 2024 12:16 pm    Post subject: Reply with quote
I have a policy with Autoaid.
As a result of being a dilatory fool, I allowed it to auto renew.
It's now over 80 quid, a lot on a limited pension...Plus, I haven't used it in years now.
I also noted that they had inserted an age limit on vehicles they attend, so I emailed them demanding cessation of my newly acquired policy, because I have either no intention of, or being able to afford to, obtain a much newer vehicle!
So their policy no longer fulfilled my needs, through no fault of mine!
I had always had the same, now 21 year old, vehicle .
I have now received an email informing me that my policy now has an add-on clause allowing me to have cover on ''any age of vehicle''....
I think I still have to find ?25 to pay the driver if I ever break down...in my old Suzuki GV....which I never used to have to do.
What peaves me more is that, on doing a bit of research, I find that the Autoaid sister operation do the vehicle-specific recovery section
Used to be all one, with a choice of vehicle, or policyholder, having the cover.
For my vehicle {age irrelevant } it would cost me under ?30 for recovery cover.....
I am considering whether to suck up the ?15 admin charge to cancel my policy, and take our their vehicle-specific cover instead?
I had policyholder cover originally because I had more than two daily drivers.....each used for a brief spell of time, so I had personal cover instead.
In fact, over the years, I have recovered more vehicles for friends & neighbours than have needed it myself...
Also, I am not afraid of getting my hands dirty & oily, but nowadays struggle to stand up from the kneeling or laying down position...
PostPosted: Thu Apr 11, 2024 12:17 pm    Post subject: Reply with quote
PostPosted: Mon May 06, 2024 2:46 pm    Post subject: Reply with quote
Well, we're all getting over colds here and with the weather set to rain I thought I'd spend the day clearing the garage with a view to getting the 1947 Minx out of storage. She hasn't been on the road in years and tbh I haven't started her in 3-4 years now.
It's also very awkward as she is facing into the garage and the Hillman alligator bonnet needs quite a bit of room to open fully and at present I can't do that. The plan is to today, get her started and turn her round.
Well I spent and hour or two decluttering to give space to move her, then I pushed her out a couple feet so I could open the bonnet. I charged a battery, hand primed her for fuel and checked the oil and water...once the battery was connected I gave her full choke and on her first pull of the started she fired into life, all be it stodgily.
I managed to get her out onto the driveway where I could then pump all the tyres up and I also removed all the hubcaps to check wheel nut tightness. I turned her around and then just as a large downpour started I reversed her back into the garage.
My plan I think is to insure her for the summer and now with my commute only being about 25 mins across the Somerset levels it might be nice to drive her in on sunny days.
PostPosted: Fri May 10, 2024 10:33 am    Post subject: Reply with quote
I finally got serious about repairing the Chrysler. I bought a brand new 6 volt coil and a second hand Stromberg OE-1 carby from the Veteran Car Club of WA spares shed.
I washed the carby out with petrol and plenty of air, before fitting it, without touching the idling and main jets (both adjustable). The car started first time and ran well! Not bad for a 100 year old carby that has probably been off a car for decades!
I'm a happy boy again.
Keith
1926 Chrysler 60 tourer
1950 Austin A40 tourer
1999 BMW Z3
PostPosted: Fri May 10, 2024 6:06 pm    Post subject: Reply with quote
I'm still trying to replace rusty steel, holes and "repair panels" made out of what seems to be old oil cans (because of the thickness, or lack thereof, not because there are green and orange lines on them) with actual steel around the rear trailing arm mounts on my project car.
PostPosted: Sat May 11, 2024 6:46 pm    Post subject: Reply with quote
I went out to the farm where we store the big Hillman today. Took off all the sheets, covered in Barn Owl droppings!!
Gave her a good look over, oil, water, plugs etc and pumped up all the tyres. She always needs hand priming as the fuel tank is so far away from the engine. With a fresh battery in place she fired up lovely.
We tool her into Wells, about 25 mins each way so gave her a nice run.
PostPosted: Sun May 12, 2024 12:59 pm    Post subject: Reply with quote
Small but very noticeable oil leak on the top fitting of the oil filter casing on the Commer cured by adding a suitably sized fibre washer.
Then when running her up though I left the choke on full while we wandered away and came back to petrol pouring out the carb...stopped the engine and wiped it all down before starting her again with no choke and she then ran sweet on tickover without any petrol spillage.
Page 121 of 121
