Joined: 30 Apr 2013 Posts: 3816 Location: The Somerset Levels
Posted: Sun Sep 09, 2018 8:14 pm Post subject: |
Got my Commer lorry now starting everytime right on the button, the 6 cylinder petrol engine sounds lovely.
Major drawback though today, she will not select gears!?! The clutch linkage has been adjusted and looking into the bell housing you can see the clutch plate moving when the pedal is pushed. But obviously this isnt enough and she just continually grinds if you try to find gears.
We will be spliting the gearbox away to investigate, not work that we thought was needed and quite a big drawback. _________________ Various Rootes Vehicles. |
Ray the rocker
Posted: Mon Sep 10, 2018 10:52 pm Post subject: post subject. |
Hi rootes, you say you can see the clutch plate moving----is that the pressure plate? If so the centre plate is stuck to the flywheel in my opinion.happens a lot when the vehicle has been standing a while .It`s worth a try to get someone to depress the clutch pedal and try to release the plate via a slim sraper put between the flywheel and plate .Might save a lot of time you take to remove the gearbox .-----cheers ray the rocker |
Ray the rocker
Posted: Mon Sep 10, 2018 10:53 pm Post subject: post subject. |
Posted: Mon Sep 10, 2018 11:05 pm Post subject: |
You might find that the splined spigot shaft has got rusty.
I had a brand new Viva with a rusty shaft oncee and it wore out one side of the centre plate in about 1200 miles. _________________ Bristols should always come in pairs.
Posted: Tue Sep 11, 2018 7:16 am Post subject: |
Good advice Ray, we will have a look when we next go down the yard. I would prefer not stripping it all apart if I can help it. _________________ Various Rootes Vehicles. |
Posted: Wed Sep 12, 2018 4:07 am Post subject: |
If you have the room, try towing it in a high gear with your foot hard on the clutch.
Usually breaks 'em free. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Posted: Mon Sep 24, 2018 8:45 am Post subject: |
Spent an hour or so trying to free off the clutch on the Commer lorry. We are also trying to run her up for longer periods, this time she ran comfortably for 30 mins on tickover. We are hoping that warming the engine up like this will also help free off the clutch. We had a look into the bellhousing and could see the lever does move the bearing on the shaft nicely so we think it is the plate seized on. _________________ Various Rootes Vehicles. |
Ashley
Posted: Mon Sep 24, 2018 9:19 am Post subject: |
It’s a bit brutal, but jack the vehicle’s back wheels up off the ground, put it in top with the engine running, accelerate up to a high speed and with the clutch pedal down, slam the brakes on hard. Nearly always does it after a few attempts. |
Posted: Mon Sep 24, 2018 9:55 am Post subject: |
Its either that or we were thinking about towing it to bang it off. _________________ Various Rootes Vehicles. |
Posted: Tue Sep 25, 2018 1:41 am Post subject: |
Rootes75 wrote: | Its either that or we were thinking about towing it to bang it off. |
That'll do it! _________________ Mike - MVPeters at comcast.net
Farmer John
Posted: Tue Sep 25, 2018 11:32 pm Post subject: Commer clutch |
Use timber cut to length or any thing that will fit to hold the pedal in a depressed state while continuing with life.
I have removed a transmission to free a clutch when all our abusive methods failed and once at the plate and about to lever it away "you call that stuck"? it was hardly stuck at all!
The block of wood is now my goto.
John |
Posted: Wed Sep 26, 2018 9:28 am Post subject: |
On the pessimistic side I've dismantled a clutch and levering the centre plate off the flywheel the cork face broke up leaving about half stuck to the flywheel.
Posted: Fri Sep 28, 2018 6:00 pm Post subject: |
Actually at the weekend rather than today. Changed the engine oil and filter on the SS.
2½ gallons of Ford Formula F fully synthetic 5w30.
Posted: Sun Sep 30, 2018 12:20 pm Post subject: |
Absolutely brilliant morning. I cant get the Commer out of the shed so I had the idea of jacking the back end up and starting her in gear. I did this and left it running in gear for 5-10 mins then tried changing gear. It didnt work and would grind so I simply repeated letting her run then try and then on about the 5th attempt she changed gear! Bit clunky but ok, I continued to let her run and try again and after a few more attempts she finds every gear smoothly without grinding.
As you can imagine, I am over the moon! _________________ Various Rootes Vehicles. |
Posted: Sun Sep 30, 2018 12:56 pm Post subject: |
Fantastic result! Looking forward to any new pics of the truck - love the old Commers. _________________ a car stops being fun when it becomes an investment |
