Ellis
Joined: 07 Mar 2011 Posts: 1382 Location: Betws y Coed, North Wales
Posted: Wed Aug 29, 2018 4:14 pm Post subject: Replacement for Fograngers on Jaguar Mark 2 |
Ladies and gentlemen may I have your opinions and advice please.
Below is a photo of the Fogranger lights on the front of a Jaguar Mark 2 :
A traditional look and contemporary to the Mark 2. In terms of practicality of additional illumination they are useless even the alternative Spotrangers .
I know that Jaguar's designer Ian Callum caused a lot of controversy with his interpretation of an updated Mark 2 but have a look at his idea for what he has designed in their place .
I'm not into plagiarism but I do like his idea and would like to recreate the additional lights on my own Mark 2 in a similar way and be useful as well
The Fogranger or Spotranger are simply bolted on from behind through a hole in the recess.
Have any of you any ideas how he's created this idea? I thought he may have used 7" Tractor lights but someone has suggested he's used 5 3/4" driving lights from some other manufacturer.
Can you all have a think and let me know your ideas? _________________ Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet |
Ellis
Posted: Wed Aug 29, 2018 9:19 pm Post subject: |
Art, thank you very much for your reply and for taking the time and trouble to investigate and find those links. I like the second idea.
I've got plenty of time to think about this but what you given me is food for thought.
Ellis _________________ Starting Handle Expert
Posted: Thu Aug 30, 2018 12:49 am Post subject: |
Ellis wrote: | Art, thank you very much for your reply and for taking the time and trouble to investigate and find those links. I like the second idea.
Ellis |
The WFT576 will be an improvement, but not by a lot & it's a very wide fog beam. There is a spot version WLR576.
I think I'd take a look at 5 3/4" headlight units in the existing shells. See if you can find any old unit from any 4-headlamp car & see what mods might be needed to the shell - it might not be much.
Then look for Cibie 57-30-02, 57-32-02 or -07 for just the glass unit. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Ellis
Posted: Thu Aug 30, 2018 11:52 am Post subject: |
MVPeters wrote: | Ellis wrote: | Art, thank you very much for your reply and for taking the time and trouble to investigate and find those links. I like the second idea.
Ellis |
Then look for Cibie 57-30-02, 57-32-02 or -07 for just the glass unit. |
Thank you MVPeters. The more suggestions the better. The smaller size headlights from a Jaguar 420 have also crossed my mind.
At this rate I'm sure we are all going to agree on a mutually satisfactory solution. _________________ Starting Handle Expert
Joined: 14 Oct 2016 Posts: 1957 Location: East Yorkshire
Posted: Thu Aug 30, 2018 3:22 pm Post subject: |
Surely, a fog light should have a wide, but flat, beam? So the water droplets don't lift the light beam too much?
Personally I'd have a couple of spots in there, maybe linked to full beam? _________________ Dellow Mk2, 1951 built, reg 1952.
Ellis
