Riley Blue
Posted: Sun Apr 07, 2019 4:14 pm Post subject: 'Restoring' rubber gear gaiter |
I have a replacement gear lever gaiter for my Riley but I've no idea how old it is and it's not that supple. Is there anything I can do to soften it and reduce the chance of it splitting? _________________ David
1963 Riley 1.5
1965 Riley 1.5 |
Posted: Sun Apr 07, 2019 5:25 pm Post subject: |
If you have a shop doing model aircraft with rubber motors there is a rubber lubricant they use to increase the durability of their rubber bands.
Come to think of it you might find that on line.
I believe "soft soap" is an alternative for the modellers _________________ Bristols should always come in pairs.
Riley Blue
Posted: Sun Apr 07, 2019 8:16 pm Post subject: |
Thanks, I think I may have some saddle soap in a cupboard somewhere so will give it a try. If not, while tidying my garage earlier I found some Holts rubber lubricant which has 'softens' amongst its claimed properties. _________________ David
1963 Riley 1.5
1965 Riley 1.5 |
Penguin45
Posted: Mon Apr 08, 2019 12:19 am Post subject: |
Glycerine well worked in does the jib.
P454. _________________ '67 Wolseley MkI 18/85, '70 Austin MkII 1800 The Landcrab Forum. |
