Rollmop
Joined: 23 Dec 2016 Posts: 14 Location: Market Drayton, Shropshire
Posted: Mon Oct 26, 2020 12:39 pm Post subject: Mayflower compression |
Has anyone had a compression test done on a Triumph Mayflower engine?
I tested mine to check the cylinder head gasket and get a reading of 73 to 75 psi across the four cylinders. None of the Triumph technical manuals I have seen give a pressure value, is around 75 psi about right for a low mileage engine? Any info/experience would be much appreciated. _________________ Failure is not an option - in my case it is usually a feature.
1971 Herald convertible
1952 Triumph Mayflower |
Posted: Mon Oct 26, 2020 2:37 pm Post subject: Re: Mayflower compression |
Rollmop wrote: | Has anyone had a compression test done on a Triumph Mayflower engine?
I tested mine to check the cylinder head gasket and get a reading of 73 to 75 psi across the four cylinders. None of the Triumph technical manuals I have seen give a pressure value, is around 75 psi about right for a low mileage engine? Any info/experience would be much appreciated. |
I would think that is a bit low but the main thing is that they are all more or less equal. |
Sid
Joined: 20 Sep 2017 Posts: 76 Location: From whence cometh the mighty Lagonda
Posted: Mon Oct 26, 2020 10:04 pm Post subject: |
To calculate the compression in PSI, and if you know the compression ratio, multiply the first figure by 14.
edit....which is 6.8:1, therefore a compression of 95psi. |
Posted: Tue Oct 27, 2020 12:43 pm Post subject: Re: Mayflower compression |
Ray White wrote: | Rollmop wrote: | Has anyone had a compression test done on a Triumph Mayflower engine?
Agreed, if it runs and drives ok I wouldn't be concerned.
Posted: Tue Oct 27, 2020 3:59 pm Post subject: |
Sid wrote: | To calculate the compression in PSI, and if you know the compression ratio, multiply the first figure by 14.
The test need so be completed with the throttle wide open, otherwise it will read low.
Rollmop
Posted: Fri Oct 30, 2020 12:43 pm Post subject: |
Thanks for the CR formula. Once you see it it is a very obvious calculation, atmospheric pressure x compression factor. I will leave it for now but next year may have the head off to check the pistons, bores etc _________________ Failure is not an option - in my case it is usually a feature.
