mgb gt jubilee
dazdawn07
PostPosted: Wed Oct 31, 2007 1:54 pm    Post subject: mgb gt jubilee Reply with quote
Hi all well we started the strip down now, plan is to have on raod for next summer, a few qusetions,what does the overdrive do on a mg. also where do i get the engine number on my plate on engine it says bhm111 etc but on a jubilee web site they put 18v etc etc... not sure what it means
below a few pics
daz.dawn
PostPosted: Wed Oct 31, 2007 4:37 pm    Post subject: Reply with quote
Can't help with the numbers but it looks like a great project... Compared to my Sprite, it only needs a wipe with an oily rag.
Don.
UKdave2002
PostPosted: Wed Oct 31, 2007 5:53 pm    Post subject: Reply with quote
Hi Dazdawn
I may be breaking an MGB GT, if you need any bits, its complete, includes some new carbs (done 1500 miles) and and a little used stainless steel exhaust.
dazdawn07
PostPosted: Tue Nov 06, 2007 9:09 pm    Post subject: Reply with quote
thanks for that mate
so far we need is a oil cooler, nothing else as still on the strip down wont be re buiding till after new year
thanks
daz dawn
dazdawn2007
PostPosted: Mon Dec 10, 2007 8:14 pm    Post subject: Reply with quote
how do you get to the bolts to undo the doors ??? do you need to take the wing off as cant get to the bolt??? thanks
PostPosted: Mon Dec 10, 2007 8:59 pm    Post subject: Reply with quote
I have no idea, but can you not get up inside the wing?
PostPosted: Tue Dec 11, 2007 9:11 am    Post subject: Reply with quote
Unless my memory is playing tricks , there are 4 bolts per hinge which you get at from the door side of the A pillar. Or you can remove the door from the hinge, I think there are 2 bolts per hinge, you will need to remove the trim etc if you do it this way.
dazdawn2007
PostPosted: Mon Jan 21, 2008 11:34 pm    Post subject: Reply with quote
Here are a couple of the latest pictures. Any advice on what to paint underneath the car to cure the rust and preserve?
PostPosted: Tue Jan 22, 2008 3:50 pm    Post subject: Reply with quote
Hi , think have allready posted this ; below is where you need to waxoil;
Brian M
PostPosted: Tue Jan 29, 2008 8:44 am    Post subject: Reply with quote
Are similar diagrams available for other cars?
Brian
Rich5ltr
PostPosted: Mon Mar 31, 2008 6:17 pm    Post subject: Re: mgb gt jubilee Reply with quote
dazdawn07 wrote:
Hi all well we started the strip down now, plan is to have on raod for next summer, a few qusetions,what does the overdrive do on a mg. also where do i get the engine number on my plate on engine it says bhm111 etc but on a jubilee web site they put 18v etc etc... not sure what it means... daz.dawn
Hi Daz Dawn, by now I guess you are getting on with your project, any update? By the way, what did you mean when you said "what does the overdrive do on an MG?" - The overdrive is pretty straight forward, but what's your question? Confused Rgds Rich...
PostPosted: Mon Mar 31, 2008 6:22 pm    Post subject: Reply with quote
I hope those wooden props holding the bodyshell up are good n strong!!
R Confused
