NLWim
Posted: Fri Jun 20, 2008 11:05 am Post subject: sewing roofing vinyl |
I have to renew the roofing of my 1947 Riley RMA. New material is available, however not in the proper width, so parts have to be sewed together. Can anyone help me with some hints how to do the sewing and how to get it waterproof?? |
Riley Blue
Posted: Fri Jun 20, 2008 11:35 am Post subject: |
You can buy ready sewn roof kits from Riley clubs: The Riley Motor Club or Riley RM Club. No need to do any sewing and you may also find instructions on how to fit.
I've seen quite a few RMs that have had these kits fitted, they look OK to me. |
NLWim
Posted: Fri Jun 20, 2008 6:49 pm Post subject: |
Rick, the roof structure is O.K., the perforated metal was a bit rusty and I had to weld new edges to the front side. The Riley Motor Club could provide a roofing kit but had no chance shipping the dripmoulding. I found a supplier in Belgium, only 150 kms driving from where I live, who had everything I need at a fair price. The roofing kit the club supplies has two seams, there must be somebody who knows how to sew the strips watertight together?
(I tried to post a photo, unsuccesfully) |
Uncle Joe Guest
Posted: Thu Jul 17, 2008 4:46 pm Post subject: |
Only just seen this post, but theres no need to think about sealing the seam. The correct way to do things is to refinish the roof properly, ie as you would the rest of the bodywork, and then use the correct adhesive.. |
NLWim
Posted: Fri Aug 22, 2008 5:12 am Post subject: |
Uncle Joe wrote: | Only just seen this post, but theres no need to think about sealing the seam. The correct way to do things is to refinish the roof properly, ie as you would the rest of the bodywork, and then use the correct adhesive.. |
I had the vinyl sewed at a local Taylor, using the old vinyl as sample. He made a good job and used the correct adhesive. I'm now trying to put the new roof on the car. Stretching the material around the back sides is the toughest job! |
Uncle Joe Guest
Posted: Fri Aug 22, 2008 7:25 am Post subject: |
Pros have a special tool that helps with that, or you can use a hair drier.
Is the job completed now? |
