Uncle Joe Guest
Posted: Sun Aug 24, 2008 11:54 am Post subject: Number Plates |
When the new style reflective number plates were introduced, garages used to make them up. The plate itself used to be aluminium, and the numbers/letters used to be plastic ones that were held on with clips behind the plate. Is this type still available? If so, can anyone suggest a supplier please? |
Uncle Joe Guest
Posted: Sun Aug 24, 2008 4:16 pm Post subject: |
Hi Peter, yes it does. I'll send them a mail. Thanks for your link. |
Brian M
Posted: Sun Aug 24, 2008 8:31 pm Post subject: |
UJ
Another supplier, Tippers is local to me and I have been using them for many years for classic plates.
http://www.tippersvintageplates.co.uk/
If their postage costs are a bit high, I could pick them up for you and send the plates over. _________________ Brian
Uncle Joe Guest
Posted: Sun Aug 24, 2008 8:45 pm Post subject: |
Guys, this is the style of number plate I will be looking for.
The original number to the car. You can believe that I am enjoying tracing the history of the car now.... I think you can see the reason that I would like two new ones! |
Dirty Habit
Joined: 26 Mar 2008 Posts: 398 Location: West Midlands, UK
Posted: Sun Aug 24, 2008 8:51 pm Post subject: |
The name "ACE" comes to mind for those style of plates. I remember making up the jigs for punching the holes in the plates for each letter. You then pressed the protruding lug after placing a small washer on the back. _________________ 1964 International Harvester |
Uncle Joe Guest
Posted: Sun Aug 24, 2008 9:03 pm Post subject: |
Before I looked at this number plate, I had assumed the same, that they had the same locking washer on the back. Then I noticed that they were nuts. |
Brian M
Posted: Mon Aug 25, 2008 8:46 am Post subject: |
UJ
You won't get that style of backing plate or letter font in the UK. I know that Tippers are desperately short of some letters in the UK fonts, and so almost certainly won't have Euro fonts. _________________ Brian
Dirty Habit
Posted: Mon Aug 25, 2008 12:28 pm Post subject: |
Uncle Joe wrote: | Before I looked at this number plate, I had assumed the same, that they had the same locking washer on the back. Then I noticed that they were nuts. |
I remember two types used with the punched hole. The earlier letters were aluminium, that after placing a washer over the lug, you used a press to rivet them in place. The later letters were plastic and used a metal clip. Can't think of the name of that type of fastener, but you know the ones that you can't get off when you want to......or they keep coming off on their own. _________________ 1964 International Harvester |
