Shaper
PostPosted: Wed Oct 22, 2008 10:39 pm    Post subject: Shaper Reply with quote
Is it wort while having a shaper? I have never used one, what are the po's/cons, compared to a miller for comparrison?
PostPosted: Thu Oct 23, 2008 2:27 pm    Post subject: Reply with quote
You are going have to tell me what a shaper is! does it involve a gym? Wink
PostPosted: Thu Oct 23, 2008 5:57 pm    Post subject: Reply with quote
He he!
Well it is like a milling machine, but it is not rotary, it kind of works like a wood plane, moving back and forth shaving metal off as it goes.
That is my best attempt at a discription!
PostPosted: Thu Oct 23, 2008 6:09 pm    Post subject: Reply with quote
Oh
yep I have use them , they chip the metal away as you say more like a moving wood chisel, I can't recall why it would be used in preff to a milling machine that said my expirience is limited to 3 months in a machine shop, perhaps cost and speed for roughing out work?
wrinx
PostPosted: Fri Oct 24, 2008 12:02 am    Post subject: Reply with quote
Last used one of those in school....never seen one since!
I would think their uses are limited, especially compared to a milling machine.
wrinx
www.alfaromeo155.co.uk | www.alfamatta.co.uk
PostPosted: Fri Oct 24, 2008 7:50 am    Post subject: Reply with quote
I thought it would be, but was told there was certain things they can do better/more easily than a miller, what they are I am not sure.
I only ask as there is a nice one going spare at work, and it may well be going into a skip.
PostPosted: Fri Oct 24, 2008 7:56 am    Post subject: Reply with quote
Well if it's free it must be worth saving Very Happy
ROVER
One of Britain's Fine Cars
PostPosted: Fri Oct 24, 2008 12:02 pm    Post subject: Reply with quote
Funnily enough there was a film just last night in the BBC 4 railways series that showed a brief shot of a shaper in operation. Like several other respondents here, this was the first I'd seen probably since I had workshop training back in 1966.
PostPosted: Fri Oct 24, 2008 12:50 pm    Post subject: Reply with quote
Useful for splines and keyways etc, but rather a specialist machine. I'd buy a mill and subcon anything that needs a shaper, unless you are thinking of going into production making gearbox main shafts or some such.
PAUL
the fly
PostPosted: Fri Oct 24, 2008 7:52 pm    Post subject: Reply with quote
I once saw the man i worked for machine a dovetail in a large gear and make new tooth to replace a broken one . All done on a large shaping machine . Ihave a small shaper it gets little use just handy for od jobs . Ihave in the past used a hand shaper that educated me in the art of sharpening tools .My advice is if you have room for it and its not afortune cart it home .Regards The Fly
wrinx
PostPosted: Fri Oct 24, 2008 9:55 pm    Post subject: Reply with quote
Well...if there was one going free locally I'd find LOTS of uses for it Very Happy
wrinx
