1934 headlights - MOT
Timstopp
PostPosted: Tue Nov 04, 2008 6:30 pm    Post subject: 1934 headlights - MOT Reply with quote
My car has the lucas dip on one side, which then turms off the headlight on the other. I have just spent all day getting this to work(which it does nicely) Someone passing pointed out that this is now illegal.
Is it true that although standard fitment in 1934, I now have to change - and to what, they are 8 inch rims?
Thanks
tim
North Essex,UK - Morris 8 tourer 1936 - Jaguar x350
PostPosted: Tue Nov 04, 2008 6:59 pm    Post subject: Reply with quote
Timstopp,
The easiest solution would be to find another dipping solenoid and fit that. Then you will have double dipping headlamps.
Art
PostPosted: Tue Nov 04, 2008 7:16 pm    Post subject: Reply with quote
My 1932 Austin 10/4 had those headlights, didn't even try to use them because of test. Fitted some adaptor rims for a while and used Lucas 700 type units with a relay operated from the steering hub dipswitch to dip them together, used to use it at night regularly. These days I have standard looking reflectors both set in the dipped only position. Had no trouble with the MOT for the last ten years.
Don.
Timstopp
PostPosted: Tue Nov 04, 2008 9:02 pm    Post subject: Reply with quote
aaahhh
Don, so you are saying that if my headlights are on dip only ie not dazzling oncoming traffic, I am OK? (the dipping mechanism is easily disabled)
PostPosted: Tue Nov 04, 2008 9:32 pm    Post subject: Reply with quote
Had no trouble with two different test stations over the last ten years or so, but there's always the chance that one may put a different interpretation on the rules. So best check with them first.
Don.
PostPosted: Tue Nov 04, 2008 10:26 pm    Post subject: Reply with quote
Most MOT testers are sympathetic when it comes to testing old cars. I always give the reason "It was built that way so it isn't required" Wink
ROVER
One of Britain's Fine Cars
PostPosted: Tue Nov 04, 2008 10:41 pm    Post subject: Reply with quote
Rick, you might like to put this link somewhere suitable as a sticky so that the manual is quickly accessible for everyone.
http://www.motuk.co.uk/manual/contents.htm
Apologies if it is already here somewhere.
PostPosted: Tue Nov 04, 2008 11:05 pm    Post subject: Reply with quote
Hi Tim,
I did the same as 47jag has suggested and it has proved reliable for the last 15 years and keeps MOT testers happy. It's also a nice piece of archaic technology that amuses folk at shows etc.
It's very easy to arrange because you'll find that the non-dipping side has the bracket etc for the solenoid and these are commonly available at autojumbles.
Before I got my second solenoid I did try fitting double filament bulbs but if you focus correctly for one filament you'll find the other is wildly wrong.
PostPosted: Wed Nov 05, 2008 10:03 am    Post subject: Reply with quote
The dip and switchoff arrangement has been illegal for over 60 years and its not a matter of interpretation now of MOT rules - just lack of knowlege by the tester. However 1936 was the cut-off date for most retrospective lighting
Having said that my own 1938 Rover 16 had full MOTs' till 1996 when I bought it with a variation of this arrangement where the offside diped and nearside went out and was replaced by a low mounted "pass lamp" that is usually mistaken for a fog light - I did convert it to double dip however or safety.
Older cars like mine with the big headlamps were catered for by conversion rims to use the Lucas 7" pre-focus bulbs. I just obtained a double contact bulb holder to use a standard 36/36w double filament bulb as was standard fit in the o/s head lamp as Rover never trusted the unreliable solenoid reflector tilt device even then
Rover P2
Morris Mini Traveller Mk2
PostPosted: Wed Nov 05, 2008 4:52 pm    Post subject: Reply with quote
According to the manual 1931 is the cut off date for mandatory retrospective fitting of double dipping headlights.
Quote:
A "matched pair" is a pair of lamps which
. both emit light of substantially the same colour and intensity, and
. are both the same size and shape, so that they are symmetrical to one another.
Note: Pre 1st January 1931 Vehicles
For vehicles that are fitted with one or two optional headlamps;
. where one is fitted it must dip
. where two are fitted, either both must dip or one must dip and the other switches off.
and both dipped and main appear to be mandatory.
Quote:
1. Check that the vehicle is fitted with obligatory headlamps, as follows
a. a matched pair of main beam headlamps, and
b. a matched pair of dipped-beam headlamps
Note: Main-beam and dipped-beam functions may be provided by a
single pair of headlamps.
PostPosted: Wed Nov 05, 2008 5:48 pm    Post subject: Reply with quote
Gawd! Don't let my MOT test station know. Shocked
PostPosted: Wed Nov 05, 2008 6:35 pm    Post subject: Reply with quote
Well as I said its not a matter of opinion its a matter of law so whether or not it is broke it has to be fixed!
Rover P2
dalbuie
PostPosted: Wed Nov 05, 2008 7:36 pm    Post subject: Reply with quote
It's also law not to use your mobile phone while driving but I don't see that stopping anyone Laughing
Timstopp
PostPosted: Thu Nov 06, 2008 12:13 am    Post subject: Reply with quote
I have checked the non dipping headlight, and it cannot be converted without a whole new inside, so it would appear my only option is to araldite a 7 inch modern unit and hack the wiring to bits, or hack off the headlights altogether and fit something modern.
Thats no way to treat an old car!
i may try to get a "daylight hours only" MOT - I believe these do exist)
dalbuie
PostPosted: Thu Nov 06, 2008 12:22 am    Post subject: Reply with quote
Quote:
except those which either have no front or rear position lamps or have such lamps permanently disconnected, painted over or masked
Means you'd need to disconnect everything. Best to just put it in for the test - there's a good chance the examiner won't pick anything up.
