Posted: Tue Feb 24, 2009 8:44 pm Post subject: Starter & solenoid |
What are the symptoms of a duff solenoid? just curious as the Austin isn't turning the engine over on the starter (the starter spins, a little slowly at first, but the pinion isn't engaging the ring gear, yet appears to be free on the shaft). I'm wondering if the feed to the starter is weak, meaning it hasn't got the ooomphh to chuck the pinion out enough.
I tried bridging the contacts on the solenoid but it didn't help, nor did pressing the button on the end of it. The starter still whirred but didn't engage.
Battery is charged up, engine earth to frame is good.
Posted: Tue Feb 24, 2009 9:19 pm Post subject: |
Doesn't sound like the solenoid, if it was dirty contacts the bridging trick should have worked.
What about the bendix thread, could the gear be sticking rather than being thrown to mesh with the ring gear?
I have heard that they shouldn't be greased/oiled, so could some oil have got in there causing it to bind? _________________ Bristols should always come in pairs.
Joined: 16 Oct 2008 Posts: 1132 Location: Upper Swan, Western Australia
Posted: Wed Feb 25, 2009 8:43 am Post subject: |
Hey Rick,
It sounds as if you have either a bendix problem, which as Penman says, should not be greased or oiled. Wash thoroughly with kerosine or petrol and air blow it completely dry.
It could also be badly worn brushes or a very dirty commutator in the starter. This could reduce the speed of the starter to be insuffucient to throw the bendix into the starter ring. Either way you would need to remove the starter from the car.
If you have a spare starter, then I would try changing over. That way you'lll learn if it is the starter motor or not.
Hope this helps - Keith |
Posted: Wed Feb 25, 2009 11:54 am Post subject: |
A test that might help would be to ease the starter motor out as far as possible from its housing and spray a cleansing solvent onto the bendix thread if that is possible. you might be lucky enough for the solvent to wash away sufficient gunge for the pinion to move properly on its thread.
If it works, you know to strip and clean it properly in the future, perhaps next oil change, if it doesn't work, it has cost a bit of time. _________________ Dane- roverdriver but not a Viking. |
Posted: Wed Feb 25, 2009 6:20 pm Post subject: |
All sorted now.
I took the starter off, cleaned it up and tested it on the bench using a spare battery, after making sure the brushes were free etc. It whizzed over in the correct way, so back on it went. Tried the key and diddly squat once more, just a lethargic whirring noise from down below. I connected the spare battery direct to the starter in-situ, and it churned the engine over, albeit slowly.
Turns out the battery in the car was duff after all. With the spare battery fitted in the car, the engine turned over normally and it fired up ok.
As I'd removed the filter anyway to get at the starter, it made sense to treat it to an oil change. Despite being <1000 miles since the last change, I was surprised how old the oil looked - must be all the short runs I tend to do.
