Nic Jarman
Posted: Tue Apr 07, 2009 11:04 pm Post subject: 73 MGB restoration |
We bought this MGB as it looked like it needed retrimming and not much else. The more I looked the worse it got and in the end it was a back to body shell job. I have stripped out the engine bay bits and I am lifting the engine out in the next day or two.
It will need some welding. |
Posted: Tue Apr 07, 2009 11:17 pm Post subject: |
Great cars for spare parts availabillity. Keep us posted as to the progress _________________ ROVER
One of Britain's Fine Cars |
Nic Jarman
Posted: Thu Apr 09, 2009 9:57 pm Post subject: |
Well the engine is out of the B. I decided to whip the engine out of the Midget as there are few things to be done - unleaded head, new mounts, new clutch, a clean and paint.
So I will get back to the B in a couple of weeks. |
Nic Jarman
Posted: Tue Apr 14, 2009 7:51 pm Post subject: 2 weeks? |
OK it may be just a bit more than 2 weeks.
Posted: Fri Apr 17, 2009 7:36 pm Post subject: |
"The MG Midget can easily swallow two people and their luggage."
Nic Jarman
Posted: Fri Apr 17, 2009 7:55 pm Post subject: |
| Thanks Peter. I was looking for my girl friend and her luggage. |
Posted: Fri Apr 17, 2009 8:34 pm Post subject: |
You are going that deep, you have a lead lamp going in with you!
hehe
Cheers and thanks for keeping us supplied with pictures!
Nic Jarman
Posted: Wed Apr 22, 2009 10:11 pm Post subject: |
Dave, how did you know that on the end of a bit of wire was a lead lamp? Is this old clairloyant web site?
Ignore the overspray, I will clean it off sometime. Am I getting old or does that look quite sexy |
Dirty Habit
Posted: Thu Apr 23, 2009 8:27 pm Post subject: Re: 2 weeks? |
| Nic Jarman wrote: | OK it may be just a bit more than 2 weeks.
"What a stupid place to fit a ????" _________________ 1964 International Harvester |
Nic Jarman
Posted: Thu Apr 30, 2009 4:42 pm Post subject: celebrate |
OK Midget back on the road. Yee ha, lets celebrate crack open a bottle or 2 but don't let the cat have the cork screw!
Nic Jarman
Posted: Fri Jun 19, 2009 10:20 pm Post subject: |
Celebrations were much too early. The Midget vibrated like a pig and the MOT is due. I tracked down the problem to the new engine mounts - eventually - after stripping the front end of the engine to check the cam timing. I even took a photo.
The engine mounts had started to split and the under cut in the rubber did not look "right".
I could only start the car while it is on jacks as I decided to replace the rear suspension mounts as the MOT is due and I do not think these will go through.
The car should be ready for July 5th when my daughter will drive it to Takeley _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
Posted: Fri Jun 19, 2009 11:36 pm Post subject: |
| Nic Jarman wrote: | Dave, how did you know that on the end of a bit of wire was a lead lamp? Is this old clairloyant web site?
Sorry just seen this reply, I have special senses! hehe  |
