andywen8156
Posted: Sun Jun 14, 2009 8:55 pm Post subject: Tyre size |
Hi is it possible to replace the 4.50 x 17 on my morris series e with 5.50 x 17 would the extra width cause a problems? thanks |
Joined: 16 Oct 2008 Posts: 1129 Location: Upper Swan, Western Australia
Posted: Mon Jun 15, 2009 1:36 pm Post subject: |
Check very carefully that your Morris rims are wide enough for this much larger tyre. This is a safety issue.
The overall diameter will probably be larger giving the car a slightly higher top speed but with slower acceleratiom.
Also be aware that they will probably foul the mudguards (inner and outer) when the car is on full lock and make is neccessary to increase the turning circle of the vehicle by restricting the full lock of the car.
Keith |
andywen8156
Posted: Mon Jun 15, 2009 2:59 pm Post subject: |
Thank you keith that is so very helpful indeed, I wonder if its possible to fit the 5.5 x 17 on the rear and the 4.5 x on the front would that be okay for the mot? thanks once again rgds andy |
Posted: Mon Jun 15, 2009 3:18 pm Post subject: |
You could fit two different tyre sizes so long as the same size tyres are on the same axle. The problem comes when you get a puncture and only have one size spare. _________________ ROVER
One of Britain's Fine Cars |
andywen8156
Posted: Mon Jun 15, 2009 3:52 pm Post subject: |
That's a thought thanks for the advice rgds andy |
MartinC
Posted: Wed Jul 29, 2009 9:06 am Post subject: |
Your proposed size is 1 inch wider. Will bulge from the rim a bit but should be okay at 1/2" per side. Especially as you say, if only at the rear.
The MoT has nothing to do with tyre sizes so will be fine.
As said, the spare will be odd, but this is no different to most modern cars with a space saver spare. _________________ 1937 Standard Flying Twelve
1942 Bedford OYD
1947 Cadillac Fleetwood Sixty-Special
1954 Hillman Minx
1956 Austin A30
1957 Vauxhall Victor Super
1960 Car Cruiser Carousel caravan
1962 Car Cruiser Carissima caravan |
