Back in from the Cold
PostPosted: Wed Oct 07, 2009 2:27 pm    Post subject: Back in from the Cold Reply with quote
Have just resurfaced after a few years.
I live near Colchester in Essex.
I have, at last, started to rebuild my classic, been in boxes for aaagggghhhh years.
It is a DLM1 Special made in 1959 by a man called Dereck Laurence Masters, hence the registered as a DLM1.
The car comprises
Engine and gearbox - E93A
Chassis - Austin, think its a 12.
Rear axle - originaly 1930's Morris, model??, but had to change it, now from a Ford 100E
Body is two piece alluminium open top two seater with flared wings.
Paid £20 in the early 70's
Have just finished building an extention to the old garage so as to be able to do everything under cover.
Roger
PostPosted: Wed Oct 07, 2009 2:34 pm    Post subject: Reply with quote
PS
This is 1973
Hopefully soon back like this, but in its original colour Canary Yellow
PostPosted: Thu Oct 08, 2009 9:00 am    Post subject: Reply with quote
Hi there Roger, I'm in Southend, so not a million miles away.
I'd like to see some more pictures of the car as it progresses - it is certainly very unusual! Smile
Richard Hughes
PostPosted: Fri Oct 09, 2009 11:21 pm    Post subject: Reply with quote
Hi Austin
I will start a thread about the rebuild.
Mind you could look at the on going saga on here,
http://exmilitarylincs.myfineforum.org/ftopic214-0-asc-0.php
I'll bring it over from there. same website hosting
Have to put the photos in my 'bucket' account
Are you a vintage Austin.
Having trouble ID ing the chassis and axle, Austin 12, Austin 7, or a mixture.
Mind you if Austin used the same trackrod ends for all models problem solved
Roger
