Posted: Sat Feb 20, 2010 11:45 pm Post subject: Re-importing a classic vehicle from the USA. |
Can anyone give me any hints, tips or other useful information about the excercise? The vehicle was previously UK registered in 1939.
I have no idea where to start. I know there are shipping companies who handle such matters, but at what cost? Do they handle things throughout or only Port to Port? Presumably import (or re-import) documents are needed also, but where from? Are export documents needed from the USA?
Any help gratefully received, especially if based on past experience.
Dirty Habit
Posted: Sun Feb 21, 2010 9:14 pm Post subject: |
You can do it all yourself, I have several times, but have also used this company http://www.britishtransit.com/
I normally like to go get the car myself and get it to the port in the U.S. On the only occasion I didn't do that because the car was on the west coast, I used the company above, as they came recommended.
If the car was registered here, you may be able to get the original number if you have enough evidence to back it up. I know of cars that have been re-imported and given the original number. _________________ 1964 International Harvester |
Posted: Sun Feb 21, 2010 10:48 pm Post subject: |
Dirty Habit wrote: | If the car was registered here, you may be able to get the original number if you have enough evidence to back it up. I know of cars that have been re-imported and given the original number. |
The car still has its original UK registration plate built into a glass covered recess in the body at the rear, behind the bumper mounted California plate. Do you think that would be sufficient evidence? I also have a photograph of the car in use in this Country, and though rare I suppose it could be argued that it is not the same car though the same registration is clearly visible in the photograph..
At the moment I am unsure whether any original documents exist. What do you think?
Can you give me any kind of ballpark figure from the American West Coast?
Salopian
Posted: Sun Feb 21, 2010 11:09 pm Post subject: |
Dirty Habit wrote: | Y
And I know of cars that have been reimported having been shipped as unregistered bare chassis and given an "original" number!
I feel you will need some documentary evidence however and this is a really down to how lucky you are regarding the original registration records or possession of an old tax disc/logbook etc.
From what you say it sounds as if the car is such as an MG SA or similar with the period rear illuminated number plate. _________________ Jonathan Butler
traction39
Posted: Mon Feb 22, 2010 12:24 am Post subject: |
If you have the registration number, you could try the "counties" record office. I did this for a car I was trying to gain more evidence of its original registation. I had a picture only. Maybe, I was lucky, but I did receive a certified copy of the log book giving chassis and engine number for a small sum. In the event, the number is unavailable and I assume running around on some other car. _________________ Alistair
Riley 9 Special 1932 |
Posted: Tue Mar 02, 2010 10:13 am Post subject: |
Depending where the car was registered, there's an outside chance that the old registration records still survive. For instance I'm told that Kent records are still in existence, so I need to pursue them re the Austin 7. Otherwise, you'll need to hope that some old paperwork confirming the car's original registration still exists with it.
Being pre-1950 it'll come in at a lower rate of duty compared to newer vehicles.
Out of curiosity, is this by any chance a car that we talked about via email quite recently???
