Alextriumphfan
Posted: Wed May 19, 2010 11:31 am Post subject: Rover P4 1955 Six Cylinder |
Hi,
Posting for a friend.
Car starts and runs for a while then starts to falter. Backing off gas then it goes OK again. Changed fuel pump and filter but still not right.
Any ideas folks???
Anything specific to this model???
Thanks |
Posted: Wed May 19, 2010 2:20 pm Post subject: |
Could be a blocked petrol tank breather. _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
Posted: Wed May 19, 2010 7:49 pm Post subject: |
Is glass sediment bowl clean? _________________ Rover P2
Posted: Wed May 19, 2010 10:30 pm Post subject: |
This can be a symptom of water droplets in the carb. As fuel flow (demand) increases and other jets come into use water droplets can be "sucked" (not technically correct terminology) onto the jet, effectively blocking it until the demand falls. The surface tension of water prevents it passing through most jets in a carb. Constant depression carbs excepted, which can sometimes be cleared by revving and momentarily blocking the air intake. _________________ Quote from my late Dad:- You only need a woman and a car and you have all the problems you
michael1703
Posted: Thu May 20, 2010 9:17 pm Post subject: |
air leak /running lean?
at idle, if you press the piston lifter plunger does it stall/rev/remain same ? |
baconsdozen
Posted: Fri Jun 25, 2010 12:45 pm Post subject: |
I had the same problem on a P5B rover,I cleaned out the filters and checked for air leaks,drained the tank and generally played about for hours with no luck.Finally I took the main fuel pipe off and after poking about with wire and blowing through with an air line managed to shift a load of crud and the car (touch wood) has run smoothly since.
I think the muck settled on one of the bends or a join and was compacted under high demand effectively sealing the pipe.
Best of luck anyway. _________________ Thirty years selling imperial hand tools for old machinery(Now happily retired). |
