montreal
Posted: Mon Nov 22, 2010 8:36 pm Post subject: shim stock |
i have been trying for weeks to find a supplier in germany for shim stock. in the 60's we had sheets of it in the stores of the garage where i worked. is it no longer available in small quantities?
i thought i would easily find a supplier here to actually produce the shims that i need in small quantities but no.
perhaps someone can help with a solution in the uk for my 1929 praga alfa.
john. |
Posted: Mon Nov 22, 2010 9:28 pm Post subject: |
What sizes? We have some in the stores!
Where are you located? |
montreal
Posted: Tue Nov 23, 2010 7:36 pm Post subject: |
hi,
here is the list that i have been sending out for quotes without any luck and sometimes no responce.
located in germany- an englishman amongst all the mercedes people!
best wishes
john.
in cs4(or similar) shim steel:
2 x ( eg. 10"x6" ) sheets each from 1.00mm / 0.6mm / 0.3mm.
as an alternative a quote for finished circular shims in low volume numbers:
in 1.00mm: 25x53......2off
41x72......1off
50x72..... 2off
30x45......2off
30x40......2off
in 0.6 and 0.3mm:
30x45.....10off each size
30x62.....10off each size
postage by standard royal mail air parcel to germany with no signature request at this end. |
JohnDale
Posted: Tue Dec 07, 2010 5:02 pm Post subject: shim steel |
Hi,Just seen your post. If you go to uk.rs-online.com (or Google RS Components) & in the search pane write ' shim steel ' you will find all sorts of shim sheet & packets of assorted shim steel which you can purchase on-line.
Regards,JohnDale. _________________ 1958 Ford Zephyr Mk2 Convertible
1976 Ford Granada Ghia. |
