Cheap Grinders
PostPosted: Wed Jan 16, 2013 4:18 pm    Post subject: Cheap Grinders Reply with quote
I remember a similar topic not very long ago.
Recently I have been doing some serious bodywork.. What a pain changing the disc to cutting, grinding, flap, steel brush all the time. Then I worked out what to do.
I already knew Argos did one for less than £20 and when I was in B&Q I noticed they have a cheapo at about £16. Now neither of these tools will last a lifetime but at that price I now have three grinders all set up for different job.
Each is getting a chance to cool down regularly so that should extend their life.
Twenty years ago these things cost a fortune and weighed a ton. I'n't life brilliant?!
PostPosted: Wed Jan 16, 2013 4:36 pm    Post subject: Reply with quote
I've had one of these cheap grinders for years, seems indestructible. Had hours and hours of hard use and I haven't even needed the spare brushes provided.
PostPosted: Wed Jan 16, 2013 5:06 pm    Post subject: Reply with quote
Yes I know exactly where you are coming from with the irritation
of keep changing between cutting disc, grinding disc and wire brush
attachments..........
I love your plan of three grinders all set up for a different job Cool
I am on my third cheapie Clarke grinder now.... you know when they are
about to give up as they start to vibrate more than usual!! I think it
is the wire wheel that destroys them the quickest...
I'm off out in the garage now to see if I can find 3 grinders
Steve
PostPosted: Wed Jan 16, 2013 5:37 pm    Post subject: Reply with quote
I was talking to a chap who is a buyer for a large tool retail store, nearly all these tools from simple grinders to cnc milling
machines are made in china, and the cost has plummeted in recent years. However he was saying that they expect costs to rise this year as wages in china increase and the cost of steel goes up. It may be a good time to buy.....
JC T ONE
PostPosted: Wed Jan 16, 2013 10:29 pm    Post subject: Reply with quote
I bought 2 new Bosch, and had the grinder disc on one, and the cutting disc on the other.
they lasted 2 & a half Mini restoration, plus half a Volvo.
Then they both packed in Rolling Eyes now I just buy the cheap ones.
bob2
PostPosted: Thu Jan 17, 2013 9:49 am    Post subject: Reply with quote
I have bought some Skill tools in the past and though cheapish found them to be very good quality, of course they are made in china but still very good!!
welshrover
PostPosted: Thu Jan 17, 2013 12:21 pm    Post subject: Reply with quote
i bought a cheapy grinder from tatton park show about 15 years ago cost me a fiver still going strong today . i also bought a bosch one around 1987 time £ 70.00 then, long gone now it lasted about three years . Confused
JC T ONE
PostPosted: Thu Jan 17, 2013 1:38 pm    Post subject: Reply with quote
I see a pattern here Rolling Eyes
still have a Bosch drill thou, and it still works.
PostPosted: Thu Jan 17, 2013 4:44 pm    Post subject: Reply with quote
Update regarding B&Q grinder.
DO NOT BUY.
I must admit it's not had an easy week, but this is still its first week and the wires are coming out of the back. It must be unable to take normal pulling and twisting because I haven't misused it; I would tell you if I had.
So it's going back tomorrow.
The Argos one still motoring well.
welshrover
PostPosted: Thu Jan 17, 2013 9:33 pm    Post subject: Reply with quote
ive got a bosch drill too and thats still going strong its about 10 years old now .it seems their drills are better than their grinders. Rolling Eyes
baconsdozen
PostPosted: Mon May 20, 2013 1:39 pm    Post subject: Reply with quote
A long while ago I bought a cheap Silverline angle grinder.Some of their stuff does leave a bit to be desired in terms of quality but this has been used and abused ever since.The only thing thats gone wrong is the hold button to lock it whilst changing discs and the switch is a bit stiff.
To be fair if it now packed up totally and ended up in the bin it would still have earned its keep a few times over.
PostPosted: Mon May 20, 2013 2:05 pm    Post subject: Reply with quote
Another Clarke CAG22 angle grinder lost it's drive on me last week, it was new
in January this year. However (and perhaps contrary to previous advice)
I took it back to Machine Mart and they exchanged it for a new one....
Bearing in mind it only cost about £20, good service I reckon Smile
Lets see how long this one lasts......
PostPosted: Mon May 20, 2013 6:27 pm    Post subject: Reply with quote
I recently got a Draper 600w grinder from the local Wilko a few weeks ago for £18, which has been pretty good so far (only about 4-5 weeks) and is a bit quieter than my others. Popped in today for something else, they're £19.80 now!
pogo
PostPosted: Mon May 20, 2013 7:24 pm    Post subject: Tools Reply with quote
Are 'Energiser' tools available in the UK?
Here in France, I have bought quite a few energiser tools (black and dark blue), and bearing in mind I an using them on VERY heavy duty work, like cutting and knocking through 1/2 meter wide granite walls, none have failed on me. I bought a large 250mm cutter/ angle grinder for €50, and its cut through numerous stones, and the €50 breaker drill has been on the go for 2 days in a row now , as well as loads of previous work.
Highly recommeneded if you can get them.
Paul
http://www.centralfrancestorage.com/index.html
