DELETED Guest
Posted: Tue Nov 20, 2012 8:49 pm Post subject: primer |
| DELETED |
Desert Fox
Posted: Fri May 24, 2013 10:03 am Post subject: Re: primer |
| wilson294 wrote: | | Use 2 pack high build epoxy its 10 quid a litre its very good very sticky and it goes on bare metal without the kneed for etch primer |
All non-ferrous metals require an etch primer unless the epoxy is specifically designed for use without etch primer. If not, the paint adhesion will fail. |
