matekra
Posted: Sun Jun 09, 2013 11:42 pm Post subject: |
It's difficult to separate the noises but I think I can hear a bit of crankshaft rumble, some exhaust blowing and maybe valve clearance needing adjustment. It would have been helpful if we could have seen the oil pressure. Is the exhaust leaking? If so fix that. Check the valve clearances, it should be INLET= .015" and EXHAUST=.018" with the engine hot. Check these things and get back to us.
