Steering wheel play On Ford model y
alapimba
PostPosted: Mon Jun 10, 2013 2:25 pm    Post subject: Steering wheel play On Ford model y Reply with quote
Hello
My car failed the portuguese equivalent mot due to steering wheel play (45°- 1/Cool.
The steering box is of the worm And nut type And the nut is not new anymore.. Thats the reason for the play On the steering wheel .
Theres any trick to solve this as i can find a new nut neither no one to rebuild it. I filled the box with grease but the gap Didnt reduced..
Regards
PostPosted: Mon Jun 10, 2013 2:26 pm    Post subject: Reply with quote
Is there any adjustment available on the box itself? sometimes there is an adjusting screw which can be altered, after loosening a lock-nut.
alapimba
PostPosted: Mon Jun 10, 2013 2:41 pm    Post subject: Reply with quote
Originaly no theres no adjust nut or screw. All gaps inside the box were eliminated, except the one On the nut
PostPosted: Sun Jun 16, 2013 8:07 am    Post subject: Reply with quote
A very small amount of play gets magnified by the gearing to quite a lot of steering wheel movement. I found that most of the play on mine was not on the thread but where the peg interfaces with the nut. You can take the peg out and turn it through 90 degrees and that removes quite a lot of play.
alapimba
PostPosted: Sun Jun 16, 2013 9:08 am    Post subject: Reply with quote
Hello
What os the peg?
PostPosted: Sun Jun 16, 2013 10:08 pm    Post subject: Reply with quote
alapimba
PostPosted: Mon Jun 17, 2013 12:08 am    Post subject: Reply with quote
Thanks for the diagram
In my case we checked all that parts and they were ok.
The problem os really On the nut thread
