alec.elliot
Joined: 28 Feb 2012 Posts: 58 Location: Worcestershire
Posted: Tue Jun 18, 2013 8:19 am Post subject: Windscreen sealant |
Hi there
I have a 1936 Morris 8 although this thread probably applies to a lot of older cars.
The original sealant around the windscreen and frame had deteriorated and was allowing the screen to rattle around in the frame. When I scraped the old stuff out of the channel it didn't look like it was a preformed seal so I guess it was some sort of goo!
Can anyone recommend a suitable sealer that I could use? Would black silicone be suitable?
All the best
Alec |
Desert Fox
Posted: Tue Jun 18, 2013 8:25 am Post subject: |
| Silicon sealer will not suffice in a windscreen. I would go to a windscreen replacement depot and purchase the correct sealant. Windscreen sealant requires a primer for bonding the sealer. Perhaps they might even do it for you for a small fee. |
Posted: Tue Jun 18, 2013 8:38 am Post subject: |
Hi Alec. I recently used a black polyurethane sealant that looks like and goes on like silicone. It is significantly tougher, a bit more expensive and has great adhesive properties. Most people seem to call it "Tiger Seal". I had thought about using it for my old Austin windscreen but I am just slightly wary of this becoming just a bit too permanent repair..I am not sure you could ever get it off!
I guess the original black putty type product might have been that "Dum-Dum" stuff that they used in other places on these old cars.
I will be interested to see what other people have used. |
Joined: 23 Nov 2007 Posts: 4442 Location: South Cheshire
Posted: Tue Jun 18, 2013 9:38 am Post subject: |
Originally they were not sealed with sealer; just a rubber gasket that is folded found around the edge of the glass and pressed into the frame. You need to get the correct thickness rubber, remember that replacement glass may be a different thickness to the original! Woolies or Paul Beck stock it. Measure the glass thickness, measure the frame gap and they will be able to advise on the required rubber thickness.
If its a tourer its flat rubber, for the saloon its molded. Most sealants are silicon based, not to be confused with the windscreen adhesives, more commonly used on modern cars, and (certainly used to) require a primer.
Posted: Tue Jun 18, 2013 9:46 am Post subject: |
| Blimey dave, that's beginning to sound like a daunting job. |
Posted: Tue Jun 18, 2013 9:58 am Post subject: |
| colwyn500 wrote: | | Blimey dave, that's beginning to sound like a daunting job. |
I have just done it on my MGA ; not a job I enjoyed , I'd be inclined just to pick out the loose rubber and run a bead of silicon around the glass and frame, if you mask both the glass and the frame, you can get a neat finish; it may need doing every couple of years as the old rubber continuous to deteriorate.
V8 Nutter
Posted: Tue Jun 18, 2013 8:01 pm Post subject: |
| colwyn500 wrote: | Hi Alec. I recently used a black polyurethane sealant that looks like and goes on like silicone. It is significantly tougher, a bit more expensive and has great adhesive properties. Most people seem to call it "Tiger Seal". I had thought about using it for my old Austin windscreen but I am just slightly wary of this becoming just a bit too permanent repair..I am not sure you could ever get it off!
My Dad worked for Windshields of Worcester in the the fifties. They manufactured old style windscreen frames. The glass was always sealed into the frame with Dum Dum |
ajlelectronics
Posted: Wed Jun 19, 2013 7:45 am Post subject: |
Whatever you do, stay away from Tiger Seal. It is designed for permanent fixing of body panels etc, not good for a windscreen.
You can get a tube of the proper windscreen sealant, made by 3M. It is non setting, very messy, but does the job properly. However, it is no substitute for a well fitting seal which should be sorted before the sealant goes in to both channels. _________________ Evans Waterless Coolants
Posted: Wed Jun 19, 2013 7:48 am Post subject: |
| Thought as much. Glad you cleared that up. Sorry for misinformation given in good faith. |
ajlelectronics
NONORT
Posted: Fri Jun 21, 2013 9:14 am Post subject: |
Hi Guys I have used windscreen bonder in the past the only thing I will say is make sure that the glass does not touch the frame! I used the little cross things sold for tiling in the bathroom etc. I have also used slices of washing up liquid bottle the old fashion white plastic variety. Glue the screen into place then remove the spacers and fill in the gaps. Silicone will break down after sometime due to the effects of UV light. PS don't let her indoors catch you with the washing up bottle it may give her the idea that you are becoming domesticated!
alec.elliot
Posted: Wed Jun 26, 2013 7:49 am Post subject: |
Hi there
Thanks for all of the advice. I eventually went for a non setting compound and packed it out from the frame with spacers. Even though I say it myself it looks like a good job and now the windscreen does not rattle around in the frame! I have also replaced a lot of the corroded bolts with 0ba and 4ba.
Now to get it back in the car without disturbing the headlining too much!
Thanks again.
Alec |
Posted: Wed Jun 26, 2013 8:12 am Post subject: |
That sounds like my way of doing things Alec; "low intervention" I call it . Glad it's sorted and you can move on. Much as I love my old car I find that when it comes to getting caught in the rain, the water will come in through door gaps, the edge of the opening windscreen and even through the wooden floor and an infinite number of other places. I suspect that this is the same with many cars before the 1950's. As long as the glass has stopped rattling and holds back the torrent a little, you have done well in my opinion. |
