Restoration on my Hillman Hunter
Goto page Previous  1, 2, 3 ... 16, 17, 18, 19  Next
PostPosted: Wed Jun 26, 2013 2:39 pm    Post subject: Reply with quote
The idea of twin fans mounted in front of the rad is one Bristol have used for some time and if you use fans with black blades they don't show up too badly.
PostPosted: Wed Jun 26, 2013 3:05 pm    Post subject: Reply with quote
Ooh!!!! Good idea but don't you want them to show up...
stock-photo--raster-version-severed-hand-cartoon-94461418 by peterthompson, on Flickr
bob2
PostPosted: Thu Jun 27, 2013 7:39 am    Post subject: Reply with quote
good point colwyn500, the mechanical fan when I first restored the engine bay was sprayed in satin black, but I couldn't see it with the engine on while I was working on it so it got sprayed yellow during the engine rebuild!!
However I was referring to electric fans positioned between the grill and the radiator and there's no way you can get to them unless you take off either the grill or the radiator!
Think that is what I'll eventually end up doing, just switching them from the inside when the temperature starts to rise a little when moving slowly or when I encounter traffic!!
bob2
PostPosted: Thu Jul 18, 2013 7:41 am    Post subject: Reply with quote
Took it out for a run last sunday, my daughter and wife came for the ride as well.
It behaved itself and the temperature kept on normal throughout the trip even though we had somewhere in the region of 30/32 degrees and we encountered some traffic so I'll just skip on the idea of fitting electric fans for the time being!!
Smile
bob2
PostPosted: Mon Jul 29, 2013 9:56 am    Post subject: Reply with quote
Got the hunter out last saturday for a run, it went ok and received some looks on the way too!!
bob2
PostPosted: Mon Aug 26, 2013 8:19 am    Post subject: Reply with quote
Got this out again last saturday for a run together with my family!!
Must buy some oil and change the engine oil and oil filter though!!!
Paykan
PostPosted: Fri Aug 30, 2013 1:11 am    Post subject: Reply with quote
hi bob ! you have a nice car now, congraluation man.
bob2
PostPosted: Fri Aug 30, 2013 7:18 am    Post subject: Reply with quote
Thanks, and as I said in your thread yours is very original and has got very nice patina, I'd just clear coat it in a semi matt lacquer.
bob2
PostPosted: Mon Oct 28, 2013 10:33 am    Post subject: Reply with quote
Yesterday I took this out for a run together with my family to a garden centre, the weather was glorious and the drive was a nice one.
JC T ONE
PostPosted: Mon Oct 28, 2013 12:01 pm    Post subject: Reply with quote
Smile nice to enjoy the car, on a beautifull day Cool
will look for that JanSpeed catalouge ? and let you know if it has tuning gear for your Hunter Wink
Jens Christian
bob2
PostPosted: Mon Oct 28, 2013 12:09 pm    Post subject: Reply with quote
ok Jens thanks a lot.
JC T ONE
PostPosted: Wed Nov 13, 2013 10:00 am    Post subject: TV star Reply with quote
Your car was on TV yesterday Cool
It was in the movie "Killer Elite" with Jason Statham.
Driven by the bad guys, and even same colour as your car Cool
Also found the JanSpeed catalouge.
They did conversion sets for Hillman - Singer - Avenger .
Is the 1500 engine in the Avenger the same as in your car ?
Jens Christian
bob2
PostPosted: Fri Nov 15, 2013 9:44 am    Post subject: Reply with quote
Will have to watch it then!!
The 1500 in the avenger is not the same unit as fitted to the arrow range cars!
bob2
PostPosted: Wed Apr 09, 2014 9:19 am    Post subject: Reply with quote
Its been some time since I've updated this thread!!
In February I managed to change the oil and filter and have a general look at the underside and so on, everything looks fine although I need to repaint part of the driver side wheel on the back and part of the disc brake dust cover since one of the calipers had leaked and the paint is peeling off badly now!!
No time for it presently as I am restoring a 1940's rod braked Phillips gentleman touring bike right now!!
bob2
PostPosted: Tue Apr 29, 2014 9:59 am    Post subject: Reply with quote
This is getting some frequent use at present since I cannot use my daily.
Sharing daily duties with the blue mini or whenever I need a bigger car to take out all the family!!
Page 17 of 19
