Redex Petrol Additive
Dobbin
PostPosted: Fri Sep 13, 2013 9:13 pm    Post subject: Redex Petrol Additive Reply with quote
Like most people I like to save money where I can. This afternoon I decided to get some Redex Petrol Additive to clean the carburettor and add a drop or two into the petrol tank. I popped into Halfords on the way home from work and priced it at £5.49 for 250ml not bad I thought but would check online when I got home. Prices in fairness weren't much different so I decided to I would get some tomorrow. However, when I was in B&M discount store I saw the same stuff for £3.49. Now that's what I call a bargain. They also had Redex cleaner for diesel engines and petrol injection for the same price. I thought you might like to know in case your tempted to spend some cash on your pride and joy this weekend. Happy Motoring.
PostPosted: Sat Sep 14, 2013 9:56 am    Post subject: Reply with quote
To be honest I'd have saved the £3.49 and not bought any at all. In all the years I've been driving I've never found a fuel additive that does anything worthwhile,other than the LRP stuff but even that is of doudtfull efficiency.
I use thinners to clean a carb.
ChrisD
PostPosted: Sat Sep 14, 2013 7:33 pm    Post subject: Reply with quote
Words of wisdom baconsdozen. IMO, ALL additives for fuel, oil or otherwise are a complete waste of money.
You can be sure that anything worth adding is already in the fuel or oil, at least if its a good quality product. Companies have spent millions over the years developing them. In fact many additives are detrimental to the base product.
I'm a chemist btw....
Riley Blue
PostPosted: Sat Sep 14, 2013 7:57 pm    Post subject: Reply with quote
"Anything worth adding is already in the fuel...?
Does that include ethanol?
PostPosted: Sat Sep 14, 2013 8:18 pm    Post subject: Reply with quote
Don't underestimate the benefits of a little added snake oil.
Peter Wink
PostPosted: Sat Sep 14, 2013 8:22 pm    Post subject: Reply with quote
Ethonal was inUK fuel since the war until the 80's.. Be great to hear from members who ran vehicles in the 50's to the 80's to understand what problems they had?
cheers Dave
PostPosted: Sat Sep 14, 2013 8:34 pm    Post subject: Reply with quote
Back in the 50's there was at least one brand, I think it was Cleveland Discol, that advertised added alchohol; and I can remember working on a forecourt when we used to add a shot of UCL (Redex and/or other brands) at a rate of one shot per gallon.
I also remember taking off the air cleaner and putting a shot straight through the carb, supposedly to clean the head.
PostPosted: Sun Sep 15, 2013 6:47 pm    Post subject: Reply with quote
I'm convinced the old Redex squirt in the carb is a myth.
You can achieve the same effect with a squirt of diesel fuel. Either will temporarily increase the compression and so blow out some loose deposits in the engine or exhaust and both will give a cloud of smoke out of the exhaust when revved. Diesel has a penetrating effect so might help dislodge some of the carbon in the engine if squirted in and left for a bit.
ChrisD
PostPosted: Sun Sep 15, 2013 9:46 pm    Post subject: Reply with quote
Ethanol of course is not an "additive" you buy and add yourself, which is what I meant (although you could add some if you really wanted to!).
Its added for cleaner combustion for pollution reasons and its unfortunate that it causes problems with some classics. I haven't noticed any myself but alas we're forced to use it.
Riley Blue
PostPosted: Mon Sep 16, 2013 7:10 am    Post subject: Reply with quote
So you think that protecting against the harmful effects of ethanol by adding Frosts' Ethomix or Millers VSPe Power Plus additives is a waste of money and the endorsement of such products by the FBHVC is questionable?
